Home » Modeling » Epsilon » Cannot reproduce EVL-GMF tutorial
Cannot reproduce EVL-GMF tutorial [message #491962] Fri, 16 October 2009 14:48 Go to next message
Michalis Famelis is currently offline Michalis Famelis
I'm trying to do validation according to the EVL-GMF tutorial, but I'm failing miserably. I'm trying to reproduce the filesystem example, using the example .emf and .evl files.
I'm a bit suspicious of the way I'm doing Step 1. For creating an integration plugin I go:
New -> Project -> Plug-in development -> Plug-in project
From there I just keep the default wizard settings and don't use any of the template example plugin wizards. Then I edit the manifest according to the instructions.
However, when I fire up a new Eclipse instance, I don't get a Diagram->Validate option.
What am I doing wrong?
Thanks in advance! Smile
Re: Cannot reproduce EVL-GMF tutorial [message #491964 is a reply to message #491962] Fri, 16 October 2009 14:55 Go to previous messageGo to next message
I should have mentioned I use Eclipse Galileo.
Re: Cannot reproduce EVL-GMF tutorial [message #491971 is a reply to message #491964] Fri, 16 October 2009 15:54 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Michali,
Thanks for reporting this! I've reproduced the problem under Galileo.
The Diagram->Validate option seems to be missing indeed in Galileo (this
does not appear to be an EVL issue but a GMF one). I'll investigate and
get back to you shortly.
Dimitris
Re: Cannot reproduce EVL-GMF tutorial [message #491972 is a reply to message #491971] Fri, 16 October 2009 16:04 Go to previous messageGo to next message
Hi Michali,
In Galileo, the Validate option has (for some reason) been moved from
the Diagram to the Edit menu:
http://www.eclipse.org/forums/index.php?t=msg&goto=47919 2
I'll update the tutorial shortly.
Dimitris
Dimitris Kolovos wrote:
> Hi Michali,
> Cheers,
> Dimitris
Re: Cannot reproduce EVL-GMF tutorial [message #491973 is a reply to message #491972] Fri, 16 October 2009 16:26 Go to previous message
Hello Dimitri,
Ah, OK it works, then! Laughing
Thank you very much for finding this out!
Michalis
Re: Cannot reproduce EVL-GMF tutorial [message #582245 is a reply to message #491971] Fri, 16 October 2009 16:04 Go to previous message
Hi Michali,
Dimitris
> Hi Michali,
> Cheers,
> Dimitris
Re: Cannot reproduce EVL-GMF tutorial [message #582268 is a reply to message #491972] Fri, 16 October 2009 16:26 Go to previous message
Hello Dimitri,
Ah, OK it works, then! :lol:
Michalis
Previous Topic:Cannot reproduce EVL-GMF tutorial
Next Topic:Set source.decoration in a link when navigability is BIDIRECTIONAL
Current Time: Thu May 23 07:08:26 EDT 2013
Powered by FUDForum. Page generated in 0.02187 seconds
