| Upgrade from Eclipse Europa to Galileo [message #491874] |
Fri, 16 October 2009 06:20 |
Originally posted by: rbremer.almanid.com
I have been using the WebTools project in Europa for quite some time
now. After migrating my projects over to Galileo, however, I am faced
with a small issue, which I can't seem to avoid.
When packaging a WAR file and deploying it to a JBoss 4.0.5GA server
(this is the target we still require), a new dependency will be packed
into the WEB-INF/lib directory, log4j-*.jar. I am not referencing this
library in my code, so it has to come from a deep-reference checking
inside of the Apache AXIS library I am using for web service client
calls.
This, of course, brings up problems during deployment, as the jboss
server doesn't like the new log4j library and throws a bunch of
exceptions.
Is there any way to avoid this dependency to be included or do I need
to switch the target to a newer JBoss release? I am not sure I can do
that though, cause we need to support quite a number of existing
installations.
BTW: I have not altered any settings on the project, so the facet's
are still the same as they where in Europa.
Any insight would be highly appreciated.
Ronny
FUDForum. Page generated in 0.01550 seconds
