Home » Modeling » OCL » OCL Parsing order matters! Is there a solution?(About OCL Parser 1.2.3)
OCL Parsing order matters! Is there a solution? [message #491082] Tue, 13 October 2009 04:03 Go to next message
Skander Turki is currently offline Skander Turki
I have several files to parse and then to check on a UML model, but i found out that the parsing order matters, in fact, when a method calls another one that is not yet parsed, an error occurs (OCL 1.2.3).
Does anybody know about a solution to this problem?
Re: OCL Parsing order matters! Is there a solution? [message #491327 is a reply to message #491082] Wed, 14 October 2009 03:36 Go to previous messageGo to next message
Hi Skander
The OCL specification does not define whether forward references work;
indeed it doesn't actually define whether backward references work either.
MDT/OCL 1.x does not support forward references.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=187679 suggests
implementing forward references and raising a corresponding OMG
Issue to make the specification clear.
For now, you must avoid forward references.
Ed Willink
Skander wrote:
> another one that is not yet parsed, an error occurs (OCL 1.2.3). Does
> Thanks
Re: OCL Parsing order matters! Is there a solution? [message #491344 is a reply to message #491082] Wed, 14 October 2009 04:42 Go to previous message
thanks for your clear answer.
Previous Topic:OCL 2.1 Spec available?
Next Topic:OCL in Transition's Guard to access trigger properties
Current Time: Tue May 21 10:04:58 EDT 2013
Powered by FUDForum. Page generated in 0.02329 seconds
