Home » Eclipse Projects » Rich Client Platform (RCP) » Command Parameters
Command Parameters [message #490153] Wed, 07 October 2009 10:55 Go to next message
Bob Walker is currently offline Bob Walker
Member
I'm sure this must have been asked a thousand times, but I can't find a definitive answer anywhere.
I want to pass a domain object to a Command handler, but of course Command parameters are String objects. I read that String command parameters are really for view ids or similar, which is fine - it feels wrong and fragile to pass around simplified Strings lookup keys for my own domain objects, and I won't always necessarily get my data from a selection provider, so is there an accepted way to do this?
As I type this, I'm wondering if it is a design flaw on my part to not get my data from a selection provider? Is that the correct way to do it?
Any pointers gratefully received,
Bob Walker
Re: Command Parameters [message #490246 is a reply to message #490153] Thu, 08 October 2009 01:09 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.
I *think* the decision of passing strings as parameter was made to
facilitate the contributions in plugin.xml. It is not necessary to get
the data from the selection provider always. Your handler can get the
values from an ISourceProvider. Like I've done here
( http://blog.eclipse-tips.com/2009/02/commands-part-5-authent ication-in-rcp.html)
- Prakash
Platform UI Team, IBM
Re: Command Parameters [message #490711 is a reply to message #490153] Fri, 09 October 2009 15:00 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
I guess the answer is "it depends" <- less helpful Smile
Really, it depends on the command. For most commands, it is reasonable for it to act on the current selection if that selection is a useful type. i.e. select a "Connection" object in your view and execute the "Connect" command. This is the main pattern facilitated by the JFace viewers and getSite().setSelectionProvider(*).
But there are other cases, where you want to execute a command on an object and specifically want to avoid posting it as the current selection.
Just w.r.t. design:
The parameters in commands are designed to "modify" the behaviour of that particular command execution. Like "move(direction=forward)" or "showView(viewId=outline.view.id)". But command parameters don't serve quite the same purpose as the parameters in a method call. But because the main situation they parameterize are menu items and keybindings, they are pretty static. They can be objects (there are parameter value converters) but they need to support serialization.
The way to pass object state (like a model object) to an executing handler is through the application context. If you are executing your command programmatically through the IHanderService you can update the IEvaluationContext that will be used in the ExecutionEvent and set your object to a known variable.
If you want the correct model object to be available to your command on its own timetable (database is connected, events have come in, connections made, etc) you can use an AbstractSourceProvider to make your model object available to the application context.
PW
Re: Command Parameters [message #491103 is a reply to message #490153] Tue, 13 October 2009 05:41 Go to previous message
Member
Excellent, thanks guys, most helpful, that gives me just what I need.
All the best,
Bob
Previous Topic:Wizards
Next Topic:Command at the wrong view active.
Current Time: Sat May 18 04:25:27 EDT 2013
Powered by FUDForum. Page generated in 0.02608 seconds
