| [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #487886] |
Thu, 24 September 2009 13:00  |
Toñi Reina Messages: 197 Registered: July 2009 |
I'm working with different projects and I usually define the
following directory structure.
Project
|----metamodel
|----model
|----transformations
The problem is that every time I want to change the project, I also
have to change the MofScript Preferences configuracion. I haven't found
any way of specifying different paths for different metamodels,
transformations, and so on. Is there any way to do this or to attach the
preferences to a concrete project?
Toñi
| Re: [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #580089 is a reply to message #489018] |
Thu, 01 October 2009 12:51  |
But all the preferences, metamodel path, model path and transformation
path??
Gøran K. Olsen escribió:
> Hello Toñi,
> No there is not a way to do this. Normally I just set the preferences to the
> Workspace location.
> /Gøran
> "Toñi Reina Quintero" <reinaqu@lsi.us.es> wrote in message
> news:h9g8jg$dt$1@build.eclipse.org...
>> I'm working with different projects and I usually define the following
>> Project
>> |----metamodel
>> |----model
>> |----transformations
>> Best regards,
>> Toñi
FUDForum. Page generated in 0.01785 seconds
