Home » Modeling » OCL » LET and IN
LET and IN [message #490136] Wed, 07 October 2009 09:06 Go to next message
Eclipse User
Originally posted by: formatzeh.gmx.de
As I commented in another thread I don't get LET expressions working.
For example the following:
let aspectParams: Set(MyMetaModel::Parameter) =
self.parentIf.parentAspect.events->forAll(ev|
ev.parameter->union(aspectParams)
in
aspectParams->includes(self.boolParam)
With that expression I want to check if the referenced boolParam is one
of the parameters of the earlier referenced events of a parent class of
the context class. I get the error in the ocl interpreter example
console that aspectParams isn't recognized. Why does it come as the code
completion does work if I use aspectParams. Another question: is the
above expression correct, especially the generation of the aspectParams
with the recursive union operation?
Re: LET and IN [message #490319 is a reply to message #490136] Thu, 08 October 2009 06:48 Go to previous messageGo to next message
Hi Gilbert
The error is correct.
You cannot reference aspectParams as the union argument while
initializing it.
Ed Willink
> in
Re: LET and IN [message #490377 is a reply to message #490319] Thu, 08 October 2009 09:51 Go to previous messageGo to next message
Eclipse User
Hi Ed,
> initializing it.
Makes sense. I thought the error comes from the latter code. Can you
help me with getting a correct initialization of the aspectParams?
Re: LET and IN [message #490486 is a reply to message #490377] Thu, 08 October 2009 15:44 Go to previous messageGo to next message
Hi Gilbert
I'm not sure what you're trying to do but if you want an updating
accumulator, you probably want to use iterate.
Ed
> Hi Ed,
>> initializing it.
Re: LET and IN [message #490517 is a reply to message #490486] Thu, 08 October 2009 18:06 Go to previous messageGo to next message
Eclipse User
But how can I add elements to the Set without using the Set?
Re: LET and IN [message #490622 is a reply to message #490517] Fri, 09 October 2009 08:54 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. Damus
--=-ovMenT8G8bPR0qVDeOPU
Content-Type: text/plain
Hi, Gilbert,
Try something like this:
self.parentIf.parentAspect.events.parameter->asSet()
in
All you need is a collect iterator, which is implicit in the dot
navigation.
HTH,
Christian
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
Try something like this:<BR>
<BR>
<TT>&nbsp;&nbsp;&nbsp; </TT><TT><FONT COLOR="#000000">let aspectParams: Set(MyMetaModel::Parameter) =</FONT></TT><BR>
<TT><FONT COLOR="#000000"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; self.parentIf.parentAspect.events.parameter-&gt;</FONT> </TT><TT>asSet()</TT><BR>
<TT>&nbsp;&nbsp;&nbsp; </TT><TT><FONT COLOR="#000000">in</FONT></TT><BR>
<TT>&nbsp;&nbsp;&nbsp; </TT><TT><FONT COLOR="#000000">aspectParams-&gt;includes(self.boolParam) </FONT></TT><BR>
<BR>
All you need is a collect iterator, which is implicit in the dot navigation.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-ovMenT8G8bPR0qVDeOPU--
Re: LET and IN [message #490964 is a reply to message #490622] Mon, 12 October 2009 11:41 Go to previous message
Eclipse User
> navigation.
Ah Ok, thank you very much
Previous Topic:N00b OCL expression question to compare URI
Next Topic:Extending OCL standard library with function returning Sequence(T)
Current Time: Wed May 22 16:43:59 EDT 2013
Powered by FUDForum. Page generated in 0.01795 seconds
