| Overriding oclIsUndefined method? [message #489359] |
Fri, 02 October 2009 11:13  |
Bence Ol Messages: 4 Registered: July 2009 |
Junior Member |
Hello
I would like to override oclIsUndefined method to change the behaviour to be domain specific.
EEnum field cannot be empty (it is always initialized with the default value), however in my model the default value of Enum is 'NULL', so
the overriden oclIsUndefined would have to return true in case of 'NULL'.
How can I override oclIsUndefined() method? I tried to add an oclIsUndefined new custom method as it is described in the help, but it was never called.
Bence
| Re: Overriding oclIsUndefined method? [message #489372 is a reply to message #489359] |
Fri, 02 October 2009 12:12  |
Ed Willink Messages: 3151 Registered: July 2009 |
Hi Bence
I think you may have to dive in to the Java code if you want this now.
I have raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=291220
to ensure that we support this hopefully in the next release. I suspect
we have at least two limitations that will prevent it working at present.
However you didn't provide your code. I think it is
EEnumLiteral::oclIsUndefined that you need to override.
Ed Willink
Bence Ol wrote:
> Hello
> was never called.
> Bence
FUDForum. Page generated in 0.02338 seconds
