Home » Archived » P2 dev » Where does the p2 mirror application put error logs?
Where does the p2 mirror application put error logs? [message #489318] Fri, 02 October 2009 08:17
Oisin Hurley is currently offline Oisin Hurley
I'm starting to use the p2 mirror application to produce local copies
of selected projects to save download times. Results have been
sporadic, in that much of the time the mirroring has not succeeded.
I have been passing this off as an issue with the Eclipse downloads
site suffering from some mirroring issues itself over the past week
or so.
Attempting to diagnose problems is made more difficult by the
fact that p2 mirror doesn't seem to drop logs, even though it says
it has done so.
Example - using the command
eclipse -nosplash
-application org.eclipse.equinox.p2.artifact.repository.mirrorApplication
-source http://download.eclipse.org/tools/gef/updates
-destination /opt/eclipse-mirror/gef
-destinationName "Local Eclipse Mirror"
-verbose -compare
will give the response
Mirroring: osgi.bundle,org.eclipse.gef.examples.logic,3.2.0.v20060626 (Descriptor: canonical: osgi.bundle,org.eclipse.gef.examples.logic,3.2.0.v20060626)
Mirroring: osgi.bundle,org.eclipse.gef.examples.logic,3.2.0.v20060626 (Descriptor: packed: osgi.bundle,org.eclipse.gef.examples.logic,3.2.0.v20060626)
Mirroring completed with warnings and/or errors. Please check log file for more information.
Log file location: /opt/eclipse351/configuration/1254485242658.log
however, the location reported for the log doesn't exist, and a find on
the entire filesystem shows up no files with that name.
Where could the mirror command be putting the log?
--oh
Previous Topic:Installing custom plugins using p2 doesn't work
Next Topic:ProvisioningEventBus could not be obtained. Metadata caches may not be cleaned up properly.
Current Time: Thu May 23 00:49:31 EDT 2013
Powered by FUDForum. Page generated in 0.03954 seconds
