Home » Eclipse Projects » Rich Client Platform (RCP) » Loss of Mouse events and OBSCURED widgets
icon13.gif  Loss of Mouse events and OBSCURED widgets [message #489296] Fri, 02 October 2009 05:45 Go to next message
Thomas SZADEL is currently offline Thomas SZADEL
Member
Hi all,
I'm currently developing an RCP application (Eclipse 3.4.1 on Linux Redhat 5).
Basically, I need a view that contains a grid of buttons (let's say 4 rows x 6 columns).
These buttons need to be big, flat and with a solid color.
They are created at the begining and never destroyed.
Each time the user clicks on a button, the whole grid is repainted and the buttons can have a different color, visibilty and or text.
Problem: after up to 1h30, the buttons are slowly dying one after the others... They no more receive any mouse event.
In debug mode, I have seen that the Display#runDeferredEvents does not receive any event when the mouse is over them.
The widget that is related to the button has its state sets to SWT.OBSCURED.
At the begining, I used a "custom" button built on a Composite (SWT.BORDER) with a child label (SWT.CENTER) and a mouse listener.
==> The problem appears after 30 min
I have seen in the doc that the SWT.CENTER flag may cause an OBSCURED state under Linux.
Thus, I have removed all the Labels and now, I draw the text (thanks to a PaintListener)
==> The problem appears after 1h / 1h30
I have replaced the Composite by a Canvas: same result
I have replaced the Canvas by a real SWT button: same result
Finally, I have removed all the buttons and replaced them by a single Canvas on which I paint all the buttons by myself.
==> it seems to works Smile
... but unfortunately, I have another view that contains a button, a table and labels... and sometimes the problem occurs Sad
... and I can't redraw by hand the whole application!!!
So, can anybody help me???
Thanks!!
Re: Loss of Mouse events and OBSCURED widgets [message #489706 is a reply to message #489296] Mon, 05 October 2009 11:34 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
I have not heard of a problem like this before. When you say the whole grid
is repainted, do you just mean you invoke
setForeground()/setVisible()/setText() on some/all of the Buttons? The
symptoms give the impression of running out of memory, so maybe there's a
leak in swt? Are you able to provide a snippet based on your app that shows
the problem happening (ideal template:
http://www.eclipse.org/swt/faq.php#whatisasnippet )? Also, are you able to
try with eclipse 3.5.1 (
http://download.eclipse.org/eclipse/downloads/drops/R-3.5.1- 200909170800/index.php )
Grant
"Thomas SZADEL" <thomas.szadel@atosorigin.com> wrote in message
news:ha4i3h$7tj$1@build.eclipse.org...
> Hi all,
5).
x 6 columns).
SWT.OBSCURED.
state under Linux.
PaintListener)
> ==> it seems to works :)
and labels... and sometimes the problem occurs :(
> Thanks!!
Re: Loss of Mouse events and OBSCURED widgets [message #489834 is a reply to message #489706] Tue, 06 October 2009 04:03 Go to previous messageGo to next message
Member
Thanks Grant for your response Wink
Grant Gayed wrote on Mon, 05 October 2009 11:34
That's it: I can change the foreground/background, the text, the visibility... but the button is no more responding to the mouse events...
The symptoms give the impression of running out of memory, so maybe there's a leak in swt?
This is what I thought... but it's not Sad
The application uses 16Mb (heap - measure done with jconsole) and up to 256 Mb are allowed.
I have already tried with eclipse 3.5 SR1... no success... is there a important change with the 3.5.1?
Unfortunaltely, I can't give you a snipped... as I can only reproduce the bug on my customer platform :\
Here is the operating system: Linux RedHat 2.6.18-128.el5 / gtk2-2.10.4-20.el5 / xorg-x11-server 1.1.1-48.52.el5 / jdk 1.6.07
My customer has informed me that its window manager is a custom one (based on wm2)... perhaps it is related...?!
Re: Loss of Mouse events and OBSCURED widgets [message #489919 is a reply to message #489834] Tue, 06 October 2009 09:42 Go to previous messageGo to next message
Nothing specific related to this problem, later versions just generally work
better than earlier ones.
Perhaps, or related to the gtk version. Are they able to try on their same
machine with a more standard window manager? Or, if there's a snippet that
fails on their machine, it may be reproducable on another machine with
gtk-2.10.4. It looks like they're on RHEL5, probably with 1+ rounds of
updates applied (base RHEL5 comes with gtk2-2.10.4-16.el5, which is pretty
close) . Do you have access to a RHEL5 install?
Grant
Re: Loss of Mouse events and OBSCURED widgets [message #489922 is a reply to message #489919] Tue, 06 October 2009 10:03 Go to previous messageGo to next message
Member
Grant Gayed wrote
Perhaps, or related to the gtk version. Are they able to try on their same machine with a more standard window manager?
I have asked them to try with Gnome... test is in progress Smile
No, I don't. That's their usual installation... and I don't think they are ready to change!
Now, I'm trying to rebuild the application with swt-motif (I know, it is a *testing version only*...)... hope it will work Confused
Re: Loss of Mouse events and OBSCURED widgets [message #489961 is a reply to message #489922] Tue, 06 October 2009 11:50 Go to previous message
Substituting motif should work since it's a totally different code base.
Don't worry about the *testing only* comment, it's > 99% identical to swt's
AIX and HPUX implementations. Just worry about the ugliness ;-).
Back to the GTK problem, if they still see the problem when using Gnome then
try to make a snippet (ideal template:
http://www.eclipse.org/swt/faq.php#whatisasnippet ) that makes the problem
happen for them, and log a report with SWT (
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT ).
There are RHEL5 installs available here to try this on.
Grant
news:hafio9$m07$1@build.eclipse.org...
> I have asked them to try with Gnome... test is in progress :)
*testing version only*...)... hope it will work :?
Previous Topic:Is it the same Command?
Next Topic:Automatically refresh of a viewer after a perspective switch
Current Time: Sat May 25 05:27:59 EDT 2013
Powered by FUDForum. Page generated in 0.01830 seconds
