Home » Eclipse Projects » Eclipse Platform » Own editor plugin with "F3" feature
Own editor plugin with "F3" feature [message #488891] Wed, 30 September 2009 11:38 Go to next message
No real name is currently offline No real name
I'm currently building my own editor for eclipse. In this editor I want to
use the "Open Declaration" feature.
When I try to create my own Action with "F3" as accellerator it works in
it's own way. Means, a popup is displayed and it asks which of the two "F3"
actions should be executed which is a bit annoying after a while.
I do not want to deregister the original "F3" feature to allow the user to
code java in eclipse with plugin installed. I also do not want to give a
different key to my version of "Open declaration" so the user can use his
beloved "F3" to lookup where something comes from.
Is there a way to "delegate" the "Open declaration" to a different code when
hit in my editor?
Thanks in advance :)
Re: Own editor plugin with "F3" feature [message #489001 is a reply to message #488891] Thu, 01 October 2009 03:56 Go to previous message
Dani Megert is currently offline Dani Megert
Phyxas wrote:
> Hello,
> want to use the "Open Declaration" feature.
> in it's own way. Means, a popup is displayed and it asks which of the
> two "F3" actions should be executed which is a bit annoying after a
> while.
> user to code java in eclipse with plugin installed. I also do not want
> to give a different key to my version of "Open declaration" so the
> user can use his beloved "F3" to lookup where something comes from.
> code when hit in my editor?
Your editor should provide it's own key binding scope and then you can
register your command for that scope and bind F3 to it.
Dani
Previous Topic:Freeware eclipse plugins?
Next Topic:Subversion hidden files in "Open Resource"
Current Time: Tue Jun 18 02:32:38 EDT 2013
Powered by FUDForum. Page generated in 0.04437 seconds
