Home » Eclipse Projects » Eclipse Platform » [Eclipse Live] Galileo in Action
[Eclipse Live] Galileo in Action [message #462438] Sun, 02 August 2009 10:23 Go to next message
Peter Stricker is currently offline Peter Stricker
The Eclipse Live webinar Galileo in Action is still not available on
http://live.eclipse.org/node/756 more than one month after the release of
Galileo.
I would have expected this webinar to become available as soon as possible
after the release.
Does anybody know when (if at all) it will become available or at least a
reason for the delay?
Thanks in advance,
Peter Stricker
Re: [Eclipse Live] Galileo in Action [message #468036 is a reply to message #462438] Mon, 03 August 2009 13:43 Go to previous messageGo to next message
Eclipse User
Questions about Eclipse Live should be directed to the
eclipse.foundation group (I've copied it to this response), or by
entering a bug about it in Bugzilla.
> Galileo.
> after the release.
> Thanks in advance,
> Peter Stricker
Re: [Eclipse Live] Galileo in Action [message #468469 is a reply to message #468036] Wed, 05 August 2009 11:42 Go to previous messageGo to next message
Lynn Gayowski is currently offline Lynn Gayowski
This was our first time using GoToMeeting on such a large scale and we've
had some trouble editing the files. We are still trying to work through
the issues and plan to make the recordings available. Sorry for the long
delay.
Re: [Eclipse Live] Galileo in Action [message #479099 is a reply to message #468469] Sun, 09 August 2009 03:08 Go to previous messageGo to next message
> delay.
Could you update the page http://live.eclipse.org/node/756 with an
explanation for the delay.
When do you expect the problems to be sorted out and the recordings to be
available?
Is there a bugzilla entry for this?
Re: [Eclipse Live] Galileo in Action [message #479648 is a reply to message #479099] Tue, 11 August 2009 16:37 Go to previous messageGo to next message
I added a comment under the Galileo in Action listing on Eclipse Live.
Wayne Beaton is researching more info about converting the file when he
has time, but I don't have an estimate when we might solve the problem.
Right now the file is edited but the recording playback only gives audio -
no video.
There's no bug filed at this time, but I'll suggest it as an option if
Wayne thinks the community might be able to help.
Re: [Eclipse Live] Galileo in Action [message #488725 is a reply to message #468469] Tue, 29 September 2009 17:37 Go to previous message
> delay.
Now that you have removed the page from Eclipse Live
(http://live.eclipse.org/node/756 now gives a Page not found), is there any
chance that you will release the recordings in a raw format?
Previous Topic:How to get one command to affect the visibility of another command?
Next Topic:DefaultBrowser
Current Time: Thu May 23 03:39:26 EDT 2013
Powered by FUDForum. Page generated in 0.02017 seconds
