Home » Eclipse Projects » DSDP - Target Management » Export to remote file system doesn't work
Export to remote file system doesn't work [message #488283] Sun, 27 September 2009 09:58 Go to next message
Missing name Missing name is currently offline Missing name Missing name
i cannot set up the export to a remote filesystem (ftp). It appears the "Unable to use connection" error. But the conections itself works.
I have no idea.
Here is a screenshot:
http://s4.directupload.net/images/090927/temp/suvtphik.png
Re: Export to remote file system doesn't work [message #488307 is a reply to message #488283] Sun, 27 September 2009 18:15 Go to previous message
Found the solution. The connection name has to be the host address... Maybe this should be fixed?!
Previous Topic:TCF Visual Studio build problems, cause: DIA SDK
Next Topic:Export to remote file system doesn't work
Current Time: Mon May 20 13:59:02 EDT 2013
Powered by FUDForum. Page generated in 0.01594 seconds
