Home » Eclipse Projects » Web Tools Project (WTP) » Problem with HTML content type
Problem with HTML content type [message #488248] Sat, 26 September 2009 14:27 Go to next message
S is currently offline S
Hi everybody,
we are using Velocity to manipulate html files in our projects. Since
Gallileo release I got a problem when opening these files .
I successfully added under General > Content Types > Text > HTML a new
content type name *.html.vm
When opening html.vm files, an error occured : Unsupported content-type
in Editor
I also tryed to add *.html.vm under File Associations menu but when I
click the "OK" button, the "*.html.vm" doesn't appear in the list and
the problem stays the same.
I found a workaround , but this solution doesn't give satisfaction.
I deleted *.html.vm associations and just put *.vm extensions, it works
fine.
The problem the is, for us, to distinguish *.css.vm and *.html.vm files.
As it seems to be a problem with "multiple dotted extensions", does
someone has an idea ? Should I report a bug ?
Sebastien
Re: Problem with HTML content type [message #488265 is a reply to message #488248] Sun, 27 September 2009 01:30 Go to previous message
David Williams is currently offline David Williams
These sound related:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=121059
https://bugs.eclipse.org/bugs/show_bug.cgi?id=89859
For your future searching pleasure ... these were pretty easy to find.
I went to bugzilla andvanced search:
https://bugs.eclipse.org/bugs/query.cgi
Selected 'Eclipse' classification, put "eontent type" in Summary query
line (with "contains all the strings"). Searched, found about a 100
bungs. Then used my browser search to look for 'extension' in that list,
and found a few.
HTH
Previous Topic:How to install WTP in eclipse galileo 3.5
Next Topic:JSP Validator Hates Spring's form:errors Tag
Current Time: Mon May 20 00:28:39 EDT 2013
Powered by FUDForum. Page generated in 0.02461 seconds
