Home » Eclipse Projects » Eclipse Platform » How to enable tooltips for each Table cell?
How to enable tooltips for each Table cell? [message #486694] Fri, 18 September 2009 11:36 Go to next message
Frank Du is currently offline Frank Du
Member
Hi All,
I am trying the snippet (link below) and it doesn't work. Therefore my question is how to enable tooltips for each cell in TableViewer? Thank you so much!
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet011CustomTooltips.java?view=markup
Best Regards,
Frank Du
Re: How to enable tooltips for each Table cell? [message #486730 is a reply to message #486694] Fri, 18 September 2009 16:02 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric Rizzo
Copying this to the JFace group (that's eclipse.platform.jface for the
newsgroup readers).
On 9/18/09 11:36 AM, Frank Du wrote:
> Hi All,
> you so much!
> Best Regards,
> Frank Du
Re: How to enable tooltips for each Table cell? [message #486762 is a reply to message #486730] Fri, 18 September 2009 22:46 Go to previous messageGo to next message
Remy Suen is currently offline Remy Suen
The snippet works fine for me on Linux/gtk+. How long are you hovering
over the table item? You may want to decrease the delay specified by
getToolTipDisplayDelayTime(Object).
Remy
Re: How to enable tooltips for each Table cell? [message #487900 is a reply to message #486762] Thu, 24 September 2009 14:17 Go to previous message
Member
Hi Remy,
This fixes the problem. The original setting is 2000 ms. It's a bit too long for my patience. Smile
Best,
Frank
Remy
Previous Topic:How to get the 'Delete' event in context menu of a selected item in package explorer?
Next Topic:Mouseover to see variable value
Current Time: Tue May 21 17:13:53 EDT 2013
Powered by FUDForum. Page generated in 0.05742 seconds
