Home » Eclipse Projects » Eclipse Platform » How to get the 'Delete' event in context menu of a selected item in package explorer?
How to get the 'Delete' event in context menu of a selected item in package explorer? [message #486539] Fri, 18 September 2009 02:25 Go to next message
sudhir  is currently offline sudhir
I have overridden "org.eclipse.ui.actions.ActionFactory.DELETE" action and provided more functionality at the time of 'Delete' in my application.
I have written following code to register my own Delete action like below.
private void registerXtpDeleteAction(IViewSite viewSite) {
IActionBars actionBars = viewSite.getActionBars();
if ( actionBars != null ) {
String deleteID = org.eclipse.ui.actions.ActionFactory.DELETE.getId();
orginialDeleteAction = actionBars.getGlobalActionHandler(deleteID);
if ( orginialDeleteAction != null ) {
actionBars.setGlobalActionHandler(deleteID,
new XtpDeleteAction(viewSite.getSelectionProvider()));
The problem is that, XtpDeleteAction only gets activated when I delete it by pressing "Delete" button from keyboard or from menu Edit->delete, but if I right click on a file in package explorer and select "Delete" then it doesn't call my overridden class.
What could be wrong here?
Sudhir
Re: How to get the 'Delete' event in context menu of a selected item in package explorer? [message #487019 is a reply to message #486539] Mon, 21 September 2009 10:09 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
sudhir wrote:
> application.
> below.
> String deleteID =
Right. For historic reasons many views fill the the concrete actions
into their context menu and don't invoke the corresponding command.
Hence your trick doesn't work.
Dani
> Thanks
> Sudhir
Re: How to get the 'Delete' event in context menu of a selected item in package explorer? [message #487814 is a reply to message #487019] Thu, 24 September 2009 09:46 Go to previous messageGo to next message
So what is the workaround then?
Re: How to get the 'Delete' event in context menu of a selected item in package explorer? [message #487843 is a reply to message #487814] Thu, 24 September 2009 10:36 Go to previous message
There's no workaround. The delete action is not supposed to be tweaked
but you could try the
org.eclipse.ltk.core.refactoring.deleteParticipants extension point.
Dani
Previous Topic:Splash screen and transparency
Next Topic:How to enable tooltips for each Table cell?
Current Time: Tue May 21 11:48:03 EDT 2013
Powered by FUDForum. Page generated in 0.07198 seconds
