Home » Eclipse Projects » Web Tools Project (WTP) » Error deploying webapp on local Tomcat in Windows 7
Error deploying webapp on local Tomcat in Windows 7 [message #487386] Tue, 22 September 2009 21:17 Go to next message
Daniel Serodio is currently offline Daniel Serodio
When I try to run a webapp deployed on my local Tomcat 6 installation, I
get the following error:
SEVERE: Error starting static Resources
java.lang.IllegalArgumentException: Document base
C:\Users\dserodio\workspace\.metadata\.plugins\org.eclipse.w st.server.core\tmp0\wtpwebapps\hello
does not exist or is not a readable directory
org.apache.naming.resources.FileDirContext.setDocBase(FileDi rContext.java:142)
org.apache.catalina.core.StandardContext.resourcesStart(Stan dardContext.java:4048)
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4217)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:722)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:583 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
This directory doesn't exist alright. Maybe Eclipse is having problems
with file permissions and can't create this directory? I tried manually
creating this directory but it doesn't work because no files are copied
into it.
Has anyone seen this problem? I don't have any problems of this kind in
Windows XP...
Thanks in advance,
Daniel Serodio
Re: Error deploying webapp on local Tomcat in Windows 7 [message #487522 is a reply to message #487386] Wed, 23 September 2009 10:09 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry Isaacs
The server "publish" operation should have populated that directory.
For info, see:
http://wiki.eclipse.org/WTP_Tomcat_FAQ#What_does_Publish_do_ for_Tomcat_servers_in_the_Servers_view.3F
I don't know what would be different about Windows 7 that would prevent
the publish from working. Do you see anything related displayed in your
Error Log view?
Larry
> at
> at
> at
> at
> at
> at
> at
> at
> into it.
> Windows XP...
> Thanks in advance,
> Daniel Serodio
Re: Error deploying webapp on local Tomcat in Windows 7 [message #487642 is a reply to message #487522] Wed, 23 September 2009 16:57 Go to previous message
Solved, the project descriptors (created by Gradle) were borked. I
created a new Dynamic Web Project and copied the files over and the
problem is gone.
Thanks for your help.
Larry Isaacs wrote:
> The server "publish" operation should have populated that directory. For
> info, see:
> Error Log view?
> Cheers,
> Larry
>> I get the following error:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> manually creating this directory but it doesn't work because no files
>> are copied into it.
>> in Windows XP...
>> Thanks in advance,
>> Daniel Serodio
Previous Topic:HTML text typing undo lets view jump
Next Topic:Automate WAR Export
Current Time: Wed May 22 23:56:00 EDT 2013
Powered by FUDForum. Page generated in 0.01697 seconds
