Home » Eclipse Projects » Eclipse Platform » Difference in compilation between ECJ and Javac - BCEL fails to return class fileset
Difference in compilation between ECJ and Javac - BCEL fails to return class fileset [message #487617] Wed, 23 September 2009 14:41 Go to next message
Mohanraj Loganathan is currently offline Mohanraj Loganathan
Consider the testcase E.java [1]. The constructor tries to print the class A (System.out.println(A.class) ; ). Class A intern has the references to class B, C and D. ANT tries to get the dependant classes for clas E using BCEL library.
When the class E compiled using ECJ, BCEL returns only E as dependent class. Where as javac returns A, B, C, D, E as the dependent classes for class E.
When analyzed further, i found that generated class file itself differing from ecj and javac.
javap output for ecj generated class file :
Max stack=3, Max locals=1
0: aload_0
1: invokespecial java.lang.Object.<init> ()V (11)
4: getstatic java.lang.System.out Ljava/io/PrintStream; (13)
7: getstatic E.class$0 Ljava/lang/Class; (19)
10: dup
11: ifnonnull #39
14: pop
15: ldc "A" (21)
17: invokestatic java.lang.Class.forName (Ljava/lang/String;)Ljava/lang/Class; (23)
20: dup
21: putstatic E.class$0 Ljava/lang/Class; (19)
24: goto #39
27: new <java.lang.NoClassDefFoundError> (29)
30: dup_x1
31: swap
32: invokevirtual java.lang.Throwable.getMessage ()Ljava/lang/String; (31)
35: invokespecial java.lang.NoClassDefFoundError.<init> (Ljava/lang/String;)V (37)
38: athrow
39: invokevirtual java.io.PrintStream.println (Ljava/lang/Object;)V (40)
42: return
javap output for javac generated class file :
Code:
Max stack=2, Max locals=1
0: aload_0
1: invokespecial java.lang.Object.<init> ()V (1)
4: getstatic java.lang.System.out Ljava/io/PrintStream; (2)
7: ldc_w A (3)
10: invokevirtual java.io.PrintStream.println (Ljava/lang/Object;)V (4)
13: return
Reason for BCEL failure to fetch the dependency?
1) ECJ generates the extra codes for the line System.out.prinln(A.class) line. Which is not necessary due to which BCEL is not able to get the Class reference of A from the class file. A is represented as a String and hence during the run time A gets loaded. Especially, look at the lines 15, 17 and 20.
2) Since A gets loaded via Class.forName, ANT/BCEL is not able to detect A as a dependency for class E.
where as ,
RI loads the reference of A in the byte-code itself, hence BCEL is able detect A as a dependency of class E
Why this difference in the bytecode in ECJ? is it a bug ? Any specific reason why ECJ expands the A.class fetching as reflection way.
Can i file a bug for the same?
References:
[1] E.java
Class E {
E() { System.out.println(A.class);}
[2] A.java
public class A extends B {
private D d = new D();
[3] B.java
public class B extends C { }
[4] D. java
public class D { }
[5] C.java
public class C { }
[6] BCEL Testcase :
Test program for BCEL which gets the dependency of a class --> http://illegalargumentexception.blogspot.com/2008/04/java-fi nding-binary-class-dependencies.html
[Updated on: Wed, 23 September 2009 14:57]
Report message to a moderator
Re: Difference in compilation between ECJ and Javac - BCEL fails to return class fileset [message #488311 is a reply to message #487617] Sun, 27 September 2009 19:28 Go to previous messageGo to next message
Walter Harley is currently offline Walter Harley
"Mohanraj Loganathan" <mohanraj.l@gmail.com> wrote in message
news:h9dq3u$ile$1@build.eclipse.org...
> BCEL library.
> class E.
> from ecj and javac.
What command line options did you use when compiling? I wonder whether you
are implicitly targeting different JRE versions.
Re: Difference in compilation between ECJ and Javac - BCEL fails to return class fileset [message #488323 is a reply to message #488311] Mon, 28 September 2009 02:19 Go to previous messageGo to next message
>What command line options did you use when compiling? I >wonder whether you
I am using Harmony Java which intern uses eclipse batch compiler to generate javac. Harmony Java calls the eclipse compiler. Please find the wrapper class of harmony which intern calls ecj here
I am also trying with the following ecj command line :
java <classpathto ecj.jar> org.eclipse.jdt.internal.compiler.batch.Main *.java
Both generates the identical class files.
Thanks and Regards,
Mohan
Re: Difference in compilation between ECJ and Javac - BCEL fails to return class fileset [message #488375 is a reply to message #488323] Mon, 28 September 2009 09:13 Go to previous messageGo to next message
Olivier Thomann is currently offline Olivier Thomann
This is because you don't set the compiler compliance.
You must be using a javac 1.5 or above. This means that a reference to a
Class literal is compiled using the ldc bytecode.
You must set the compiler compliance to use a compliance 1.5 or above
and you must target a 1.5 VM or above.
Add:
-1.5 or -1.6 depending what VM you want to target.
This will set the compliance of the compiler to match the javac version
you are using and it should set the appropriate default target and
source version for the corresponding compliance.
Note that you would get the same result using a javac 1.4.
Hope this help,
Olivier
Re: Difference in compilation between ECJ and Javac - BCEL fails to return class fileset [message #488395 is a reply to message #488375] Mon, 28 September 2009 10:17 Go to previous message
Hi Olivier,
Thank you so much . -1.5 /-1.6 resolves the issue.
Thanks and Regards,
Mohan
Previous Topic:Toolbar icon order
Next Topic:Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703
Current Time: Mon May 20 16:57:55 EDT 2013
Powered by FUDForum. Page generated in 0.02016 seconds
