| Problem integrating EPF plugins [message #487182] |
Tue, 22 September 2009 06:56 |
Mario Cervera Messages: 66 Registered: July 2009 |
Member |
has anyone tried to integrate the EPF Composer into a bigger RCP?? I am
trying to integrate it into MOSKitt 1.0.0 (www.moskitt.org) and I've got a
problem. I've already made some modifications to adapt the depencencies of
the EPF plugins to the technologies intalled in MOSKitt.Everything seems to
work fine but I get this error (look at the stack trace below) when opening
the form-based editors for tasks, roles etc... Any ideas?? Obviously the
path for the layout folder is incorrect but I don't know why it's building
it that way
ANY help would be appreciated.
Thanks in advance :-)
Could not open the editor:
C:\moskitt_1_0_0\file:C:\moskitt_1_0_0\plugins\org.eclipse.e pf.publish.layout_1.5.0.200909161633.jar!\layout
not found.
org.apache.tools.ant.types.AbstractFileSet.getDirectoryScann er(AbstractFileSet.java:422)
at org.apache.tools.ant.taskdefs.Copy.execute(Copy.java:453)
org.eclipse.epf.library.layout.LayoutResources.copyDir(Layou tResources.java:235)
org.eclipse.epf.library.layout.LayoutResources.copyDir(Layou tResources.java:204)
org.eclipse.epf.library.layout.LayoutResources.copyDir(Layou tResources.java:190)
org.eclipse.epf.library.layout.LayoutResources.copyDir(Layou tResources.java:178)
org.eclipse.epf.library.layout.LayoutResources.copyLayoutFil es(LayoutResources.java:248)
org.eclipse.epf.library.layout.ElementLayoutManager.init_pub lishingSite(ElementLayoutManager.java:413)
org.eclipse.epf.library.layout.ElementLayoutManager.setPubli shDir(ElementLayoutManager.java:397)
org.eclipse.epf.library.layout.ElementLayoutManager.<init>(ElementLayoutManager.java:125)
org.eclipse.epf.library.layout.ElementLayoutManager.<init>(ElementLayoutManager.java:92)
org.eclipse.epf.library.layout.HtmlBuilder.getDefaultLayoutM anager(HtmlBuilder.java:247)
org.eclipse.epf.library.layout.HtmlBuilder.setLayoutManager( HtmlBuilder.java:232)
at org.eclipse.epf.library.layout.HtmlBuilder.<init>(HtmlBuilder.java:84)
at org.eclipse.epf.library.layout.HtmlBuilder.<init>(HtmlBuilder.java:76)
org.eclipse.epf.authoring.ui.views.ElementHTMLViewer.<init>(ElementHTMLViewer.java:101)
org.eclipse.epf.authoring.ui.editors.PreviewPage.createConte nt(PreviewPage.java:79)
org.eclipse.epf.authoring.ui.editors.PreviewPage.<init>(PreviewPage.java:58)
org.eclipse.epf.authoring.ui.editors.MethodElementEditor.cre atePreviewPage(MethodElementEditor.java:1483)
org.eclipse.epf.authoring.ui.editors.MethodElementEditor.add Pages(MethodElementEditor.java:1040)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:146)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 6)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
FUDForum. Page generated in 0.07508 seconds
