Home » Modeling » MOFScript » MOFScript & Eclipse Galileo (II)
MOFScript & Eclipse Galileo (II) [message #486755] Fri, 18 September 2009 19:19
Toñi Reina is currently offline Toñi Reina
Hi again Gøran,
another problem I have is that when I open a m2t file that has been
created with the old version of Eclipse and Mofscript, the syntax is not
coloured. However, if I write the file from scratch, using the
predefined templates, the syntax is coloured.
I also have seen something else: If I create a new m2t file with
a template, and then copy the content of the non-coloured file and paste
it on the new file, the syntax is coloured. And, furthermore, I can
execute the transformation, the same transformation I told you I have
problems in the previous post.
Toñi
Previous Topic:MOFScript & Eclipse Galileo (II)
Next Topic:MOFScript & Eclipse Galileo (III). Problems with log & console
Current Time: Tue May 28 19:22:50 EDT 2013
Powered by FUDForum. Page generated in 0.04950 seconds
