| Re: [MOFScript] MOFScript and Eclipse Galileo [message #483076 is a reply to message #483034] |
Sun, 30 August 2009 16:52   |
Toñi Reina Messages: 197 Registered: July 2009 |
No, I have no problems, because I haven't tested it. As I saw the last
update was for ganymede, I thought there might have some problems, but
if you say there's no problem, I will download it and test it. In case
there are some problems, I'll post them.
Thanks and best regards,
Toñi
Gøran K. Olsen escribió:
> Hello Toñi,
> Do you have any specific problems using the last version from the update
> site?
> I have used it with Galileo and did not experience any problems.
> Best Regards,
> Gøran
> "Toñi Reina Quintero" <reinaqu@lsi.us.es> wrote in message
> news:h717ef$b0e$1@build.eclipse.org...
>> Hi all,
>> I'd like to know if there is a project for releasing a new MOFScript
>> version that works with Eclipse Galileo.
>> Best regards,
>> Toñi
| Re: [MOFScript] MOFScript and Eclipse Galileo [message #486753 is a reply to message #483115] |
Fri, 18 September 2009 18:35  |
Hi Gøran,
as I told you before, I'm testing MOFScript and Galileo. I had a
MOFScript file written with a previoius Eclipse version. The problem
arise when I try to execute the transformation. I obtain the following
error: Unhandled event loop exception
The exception stack trace is :
java.lang.ClassCastException: org.eclipse.ui.editors.text.TextEditor
cannot be cast to org.eclipse.mofscript.editor.MofScriptTextEditor
org.eclipse.mofscript.editor.MofScriptEditorActionDelegate.r un(MofScriptEditorActionDelegate.java:68)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
and the session data:
eclipse.buildId=I20090611-1540
java.version=1.6.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product
Do you have any idea about what can be causing the error?
Thanks and regards,
Toñi
| Re: [MOFScript] MOFScript and Eclipse Galileo [message #568292 is a reply to message #483034] |
Toñi
> Hello Toñi,
> site?
> Best Regards,
> Gøran
>> Hi all,
>> Best regards,
>> Toñi
| Re: [MOFScript] MOFScript and Eclipse Galileo [message #568319 is a reply to message #483115] |
Hi Gøran,
Thanks and regards,
Toñi
FUDForum. Page generated in 0.03960 seconds
