Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Using two foreground colors in Tree column
Using two foreground colors in Tree column [message #486221] Wed, 16 September 2009 15:33 Go to next message
Peter Stibrany is currently offline Peter Stibrany
Member
in my application, I use Tree widget with multiple columns. In one
column, I display standard OSGi version number, e.g. "1.3.2.qualifier".
I'd like to display qualifier part in grey, because it's not so
important for my users, but rest of version (i.e. "1.3.2" part) should
be in black. Is it possible to do this in Tree column?
Thank you,
-Peter Stibrany
Re: Using two foreground colors in Tree column [message #486226 is a reply to message #486221] Wed, 16 September 2009 15:43 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
You need to use owner draw or if you don't want to implement this your
own use the
http://wiki.eclipse.org/JFaceSnippets#Snippet049StyledCellLa belProvider
Tom
Peter Stibrany schrieb:
> Hello,
> Thank you,
> -Peter Stibrany
Re: Using two foreground colors in Tree column [message #486413 is a reply to message #486226] Thu, 17 September 2009 10:21 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
At the swt level:
http://www.eclipse.org/articles/article.php?file=Article-Cus tomDrawingTableAndTreeItems/index.html
Grant
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:h8rf4h$lt0$1@build.eclipse.org...
> own use the
> Tom
> > Hello,
> > Thank you,
> > -Peter Stibrany
Re: Using two foreground colors in Tree column [message #486475 is a reply to message #486413] Thu, 17 September 2009 14:41 Go to previous message
Member
Thank you for examples. I should be able to use these!
-Peter
Grant Gayed wrote:
> At the swt level:
> Grant
>> own use the
>> Tom
>>> Hello,
>>> Thank you,
>>> -Peter Stibrany
Previous Topic:use Eclipse build-in SpellChecking
Next Topic:Trees and Tables
Current Time: Sun May 19 23:02:31 EDT 2013
Powered by FUDForum. Page generated in 0.13061 seconds
