| Dispatching Event from Figure to EditPart [message #485946] |
Tue, 15 September 2009 11:41  |
Chris Messages: 12 Registered: September 2009 Location: Braunschweig |
Junior Member |
Hello all,
I want to react on a click on a label in a figure and pass it to the corresponding editpart in order to create a request and change the model.
What is the best practice to do so? How would I dispatch the mouseClick event to the editpart?
Thanks in advance
| Re: Dispatching Event from Figure to EditPart [message #486365 is a reply to message #485946] |
Thu, 17 September 2009 08:55   |
Junior Member |
I did not solve the problem yet tho I tried two workarounds to react on the label click inside a figure:
1) install a SelectionEditPolicy on the EditPart - add a MouseListener to the figure's label which will toggle a boolean value - from the SelectionEditPolicy's ShowSelection methode read that boolean value of the figure and execute a command
2) Add the MouseListener as in 1) - also add a ProperyChangeListener to the figure - firePropertyChange when the label is clicked - handle that Event in the corresponding EditPart
I prefer the 2. workaround but neither is very clean and follows the philosophy - "models should only be modified by commands"
So if someone has a nice and clean solution please feel free to answer!
| Re: Dispatching Event from Figure to EditPart [message #486435 is a reply to message #485946] |
Thu, 17 September 2009 11:44   |
Pascal G Messages: 157 Registered: July 2009 |
ngotme@gmx.de wrote:
> Hello all,
> Thanks in advance
I'm guessing you want some custom behavior on a single click of the
figure, so I'll start from there. First of all, you need to have a
selection tool entry in your palette. You need to modify the tool it
gives you for your own SelectionTool. The default one does not ask the
edit part for a command, and that's what we want here. So, subclass
SelectionTool, and extend the #mouseDown() method as follow:
public void mouseDown(MouseEvent e, EditPartViewer viewer)
// Let the superclass treat it before you, so its state
updates.
super.mouseDown(e, viewer);
Command command = getCommand();
getCommandStack().execute(command);
note: you may which to extend something else, such has
#handleButtonUp(), or #mouseUp(). The #mouseDown() approach was only for
quick testing. Also, I didn't do any error checking which you may or
may not need.
Then, you need to tell the selection tool entry which tool to use. There
is two way for that:
1- pass your own class to the #setToolClass() method (I had no luck with
this tho)
2- subclass SelectionToolEntry and override #createTool as follow:
public Tool createTool()
Tool tool = new Test();
tool.setProperties(getToolProperties());
return tool;
Then, all you need is an edit policy on your edit part which understand
the REQ_SELECTION and gives you the command.
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
| Re: Dispatching Event from Figure to EditPart [message #486437 is a reply to message #486435] |
Thu, 17 September 2009 11:52   |
>> Hello all,
>> Thanks in advance
> @Override
> updates.
> may not need.
> this tho)
> @Override
> return tool;
> Hope this helps.
wow, major typo. I meant:
note: you may wish to extend ...
*Nu Echo Inc.*
| Re: Dispatching Event from Figure to EditPart [message #486453 is a reply to message #486444] |
Thu, 17 September 2009 12:48  |
> Thanks for the solution Pascal! :)
> That looks like a clean solution to my problem.
> I will get back with my results in a week from now.
No problem.
The problem with #setToolClass() is still bothering me though... I think
it might be caused by not declaring Gef as an Eclipse-registerBuddy in
the manifest.mf (since the default implementation of #createTool() use
reflection to create the tool), but I'm not sure and I'm not an expert
in those thing. Could anyone confirm/test this??
*Nu Echo Inc.*
FUDForum. Page generated in 0.01747 seconds
