Home » Modeling » M2T (model-to-text transformation) » Check/Xtend: Regular Expression syntax
Check/Xtend: Regular Expression syntax [message #486335] Thu, 17 September 2009 06:23 Go to next message
Hauke Fuhrmann is currently offline Hauke Fuhrmann
Dear Xtend folks,
could you point me to some reference on the Syntax for regular
expressions for Strings in Xtend and Check?
I want to use e.g.
name.matches("MyRegex");
Where MyRegex is a regular expression. I tried to follow the Java Syntax
( http://java.sun.com/javase/6/docs/api/java/util/regex/Patter n.html ) like
name.matches("\w*");
to make sure that something only consists of word characters.
Unfortunately the syntax seems to be different.
Google didn't show me the way and the old oAW document also not
( http://www.openarchitectureware.org/pub/documentation/4.3.1/ html/contents/core_reference.html#r10_expressions_language
Hauke
Re: Check/Xtend: Regular Expression syntax [message #486630 is a reply to message #486335] Fri, 18 September 2009 09:16 Go to previous message
Sven Efftinge is currently offline Sven Efftinge
Unfortunately, you have to double the backslashes.
So it is :
name.matches("\\w*");
Sven
Hauke Fuhrmann schrieb:
> Dear Xtend folks,
> I want to use e.g.
> Cheers,
> Hauke
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Previous Topic:how exclude object from set
Next Topic:How include objects into new set
Current Time: Tue May 21 14:55:39 EDT 2013
Powered by FUDForum. Page generated in 0.02349 seconds
