Home » Eclipse Projects » SWTBot » MouseEvents with SWTBot
MouseEvents with SWTBot [message #485570] Sun, 13 September 2009 14:50 Go to next message
speedracer  is currently offline speedracer
hello,
is there a chance to make MouseEvents like MouseDown, MouseMove or MouseUp with SWTBot.
Or can I write a methode, with a syncExec Thread and there call the normal swt mouse events.?I tried that, but it does not function.
But I think I maked an error.
Re: MouseEvents with SWTBot [message #485652 is a reply to message #485570] Mon, 14 September 2009 06:54 Go to previous messageGo to next message
Daniel Weber is currently offline Daniel Weber
Member
There are methods generating mouse events in org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot. All of them are either private (mouseDown, mouseUp) or package-visible (moveMouse).
> normal swt mouse events.?I tried that, but it does not function. But I
What do you need the mouse events for?
Daniel
Re: MouseEvents with SWTBot [message #485668 is a reply to message #485570] Mon, 14 September 2009 08:25 Go to previous messageGo to next message
I want to try to implement a drag and drop function.
This function should in the first step work for swtbot treeitems
1. I get the bounds of the items,
2. I generate and fired a MouseMove event to item1
3. I generate and fired a MouseDown Event
4. igenerate and fired a MouseMoveEvent to item2
5 I generte and fired a MouseUp Events
Currently i don't know a better approach to to drag and drop, but for some of my tests I need this function.
Is there a chance to do that.
Can anybody tell me a better approach for implement drag and drop function?
Can I get an example how I can generate an swtbot Mouse Event?
Re: MouseEvents with SWTBot [message #485690 is a reply to message #485668] Mon, 14 September 2009 09:35 Go to previous messageGo to next message
Member
Hi again,
OK, drag and drop was the answer I expected :)
I have a basic implementation of drag and drop running and I'm preparing
to make it available. Stay tuned...
Daniel
Re: MouseEvents with SWTBot [message #485710 is a reply to message #485668] Mon, 14 September 2009 11:03 Go to previous messageGo to next message
Member
Hi again,
I just uploaded my Drag and Drop related changes to
http://github.com/DanielWeber/swtbot/tree/dnd
Did you have any success in building your own swtbot binaries? If so,
you can build from these sources and check if this implementation works
for you.
A patch has been attached to the Bug Report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=285271#c3
I only tested dnd from text to text and tree to tree, but it's a start.
All kinds of feedback are welcome :-)
Daniel
Re: MouseEvents with SWTBot [message #485788 is a reply to message #485710] Mon, 14 September 2009 22:09 Go to previous messageGo to next message
Ketan Padegaonkar is currently offline Ketan Padegaonkar
I like your approach of asking a widget to drag and drop itself on top
of another widget:
sourceText.dragAndDrop(targetText);
Will work on this patch over the next week.
Cheers!
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 14/09/09 8:33 PM, Daniel Weber wrote:
> Hi again,
> for you.
> Cheers,
> Daniel
Re: MouseEvents with SWTBot [message #485801 is a reply to message #485570] Tue, 15 September 2009 02:54 Go to previous message
Hello Daniel,
yes I had success binaries and could use your code for drag and drop. And it works for me.
Thanks for this patch. That saves me a lot of time. Smile
Previous Topic:Using "Headless Testing Framework" feature in a product
Next Topic:Table items background color doesn't work
Current Time: Thu May 23 07:00:41 EDT 2013
Powered by FUDForum. Page generated in 0.01722 seconds
