Home » Eclipse Projects » SWTBot » Using "Headless Testing Framework" feature in a product
Using "Headless Testing Framework" feature in a product [message #485670] Mon, 14 September 2009 08:31 Go to next message
Eclipse User
Originally posted by: cedric.chabanois.entropysoft.net
Hi !
I have two products, one for production and one for tests.
The test product is the same than production one except that it adds the
following features :
<feature id="net.entropysoft.cetl.test.feature"/>
<feature id="net.entropysoft.cetl.testcomponents.feature"/>
<feature id="org.eclipse.swtbot"/>
<feature id="org.eclipse.swtbot.eclipse"/>
<feature id="org.eclipse.swtbot.eclipse.test"/>
I also added
-application
org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,junit-results.xml
-testPluginName
net.entropysoft.cetl.plugin.test
-className
net.entropysoft.AllTestsSuite
to the program arguments
What i want for the test product is to run all the tests when launched and
generate a junit-results.xml (without further configuration or parameters)
It works except that it depends on org.eclipse.swtbot.eclipse.test feature
and so I need to delete org.eclipse.swtbot.eclipse.junit3.headless and
org.eclipse.swtbot.ant.optional.junit3 plugins from the test product.
(I can't delete them from my target platform (aka baseLocation) otherwise my
test product would not build)
I think it would be better to have two features :
- one with org.eclipse.swtbot.ant.optional.junit4_2.0.0.*-e35.jar and
org.eclipse.swtbot.eclipse.junit4.headless_2.0.0.*-e35
- one with org.eclipse.swtbot.ant.optional.junit3_2.0.0.*-e35.jar and
org.eclipse.swtbot.eclipse.junit3.headless_2.0.0.*-e35
C
Re: Using "Headless Testing Framework" feature in a product [message #485694 is a reply to message #485670] Mon, 14 September 2009 10:06 Go to previous messageGo to next message
Eclipse User
When building the test product (headless build), I have the following error
[java] [echo] !MESSAGE Invalid action syntax:
addProgramArg(programArg:formatter=org.apache.tools.ant.task defs.optional.junit.XMLJUnitResultFormatter,junit-results.xm l).
[java] [echo] !STACK 0
[java] [echo] java.lang.IllegalArgumentException: Invalid action syntax:
[java] [echo] at
org.eclipse.equinox.internal.p2.engine.InstructionParser.par seAction(InstructionParser.java:97)
It seems that equinox p2 engine transforms the arguments in a series of
action strings :
"addProgramArg(programArg:<the program args>)"
where
* addProgramArg is the action name
* programArg is the first parameter key
* <the program args> is the first parameter value
However as I use a coma in
" org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultF ormatter,junit-results.xml "
"junit-results.xml" is considered as the second parameter but equinox p2
engine cannot find ':' so it throws an IllegalArgumentException
C
Re: Using "Headless Testing Framework" feature in a product [message #485789 is a reply to message #485670] Mon, 14 September 2009 22:12 Go to previous message
Ketan Padegaonkar is currently offline Ketan Padegaonkar
The eclipse test feature was not intended to be used this way.
The intended use was to extract this on top of the eclipse directory in
the pre 3.4 era.
It does make sense to split this into 2 features for junit 3.x and 4.x
so as to avoid the hassle and reduce setup time for new comers.
Await for this with the next build of swtbot.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 14/09/09 6:01 PM, Cédric Chabanois wrote:
> Hi !
> I also added
> -application
> -testPluginName
> -className
> Cédric
Previous Topic:typeText not accepting typeText ("\"\");
Next Topic:MouseEvents with SWTBot
Current Time: Fri May 24 19:41:25 EDT 2013
Powered by FUDForum. Page generated in 0.01543 seconds
