| ddl-generation [message #485542] |
Sat, 12 September 2009 15:24  |
Marc Schlegel Messages: 92 Registered: July 2009 |
Member |
Hello again
In addition to my prior post, I have another problem with DDL generation.
When I use drop-and-create-tables I get an exception when the tables are not
available at drop time.
When I use create-tables I get an exception when the tables are already there.
Why is drop-and-create-tables not just ignoring it when there are no tables to
drop. Thats fine...it can continue with the creation. I dont want to change my
persistence.xml every time I run my testcases or drop tables in the database
manually.
Furthermore I get exception regarding a table called SEQUENCE (sometimes telling
me that it is missing, or that it is already there).
I guess I am doing something wrong in my top-down-approach. I know that in real
scenarios usually bottom-up is used, but right now I am just playing around how
to organize my object and how to map it...and currently EclipseLink seems to
have some problems with that.
Can somebody explain what I might do wrong or what I have to be aware of.
| Re: ddl-generation [message #485707 is a reply to message #485542] |
Mon, 14 September 2009 11:04  |
James Sutherland Messages: 1834 Registered: July 2009 |
Are you just seeing errors logged, or is an error occurring?
With drop-and-create EclipseLink will log errors if the drop fails, but will ignore the errors and try to create the tables, errors will only be thrown if the create fails.
With create EclipseLink will log errors if the create fails, but ignore the errors and assume the database is already created.
You can turn logging off, if you wish to not see the errors logged.
Sometimes they are useful, as a drop may have failed because of a constraint error.
James : Wiki : Book : Blog
FUDForum. Page generated in 0.01678 seconds
