| Jdbc Derby connect URL failed with a double byte language character [message #48570] |
Fri, 08 August 2008 10:31  |
Originally posted by: jinx.us.ibm.com
Hi:
When I use DTP connection profile to connect to a derby database with
UDB driver, and the database name or the path to the database has a
double byte language character, i.e.
URL:jdbc:derby:net://localhost:1527/"C:/近/mydatabase", I get the exception:
com.ibm.db2.jcc.b.SqlException: [jcc][10402][11146][3.50.152] Cannot
convert Unicode string to Ebcdic string. ERRORCODE=-4220, SQLSTATE=null
Does anyone know how I can specify a database name with a double byte
language character?
Cindy
| Re: Jdbc Derby connect URL failed with a double byte language character [message #49058 is a reply to message #48779] |
Wed, 20 August 2008 13:37  |
Originally posted by: brianf.sybase.com
Thanks Stephan for responding to Cindy's question!
--Fitz
"Stephan van Loendersloot" <stephan@republika.nl> wrote in message
news:g7q3i0$qk0$1@build.eclipse.org...
> Hi Cindy,
> This is a known problem, see:
> https://issues.apache.org/jira/browse/DERBY-728
> The workaround is to use characters of the ISO-8859-1 set.
> BTW, it is recommended to use the Derby database driver instead of the IBM
> driver.
> Stephan.
>> Hi:
>> When I use DTP connection profile to connect to a derby database with UDB
>> driver, and the database name or the path to the database has a double
>> URL:jdbc:derby:net://localhost:1527/"C:/?/mydatabase", I get the
>> exception:
>> language character?
>> Thanks
>> Cindy
FUDForum. Page generated in 0.02256 seconds
