| Mirror local archive site from command line? [message #485031] |
Thu, 10 September 2009 06:29  |
Tom Dalton Messages: 12 Registered: September 2009 |
Junior Member |
Cross posted from http://www.eclipse.org/forums/index.php?t=msg&th=154010, I'm now thinking this is a P2 problem.
Basically, I can install the emf site update via the update UI fine, by pointing it at the original .zip file. However, if I unzip it and point it at the unzipped archive then the install starts off looking ok, with the progress bar chuntering along, but when it gets to about 60%, it bombs out with a mass of file not found errors, because it's looking for the plugins as plain .jar files when they are actually .jar.pack.gz files.
Now this would be fine, if I could recreate the former method via the p2 director. However, from the documentation I've read, I can't see a way to get it to accept the original .zip file as being a valid repository, and if I unzip it myself and point the director at that, I get the file not found errors the same as if I was doing it through the latter UI method.
This is causing me a big headache - I don't know if this is expected behaviour or if I have found a bug.
| Re: Mirror local archive site from command line? [message #485343 is a reply to message #485031] |
Fri, 11 September 2009 08:59  |
Junior Member |
RESOLVED via p2-dev mailing list - see email change below:
Thank you for the response - I'll let the EMF team know there's a problem at their end.
Using the jar:file type URI to point at the .zip seems to work in the meantime, so I'm a very happy bunny.
Tom
From: p2-dev-bounces@eclipse.org [mailto:p2-dev-bounces@eclipse.org] On Behalf Of Pascal Rapicault
Sent: 10 September 2009 18:00
To: P2 developer discussions
Cc: p2-dev@eclipse.org; p2-dev-bounces@eclipse.org
Subject: Re: [p2-dev] Issue running p2 director
The artifact repository contained in this archive is inconsistent. It has been made inconsistent by the EMF build process which deletes the canonical jars to only leave the pack'ed one, but does not update the artifact repository index (artifacts.jar) to reflect this change. Please report this problem to the EMF team.
The reason why this is working in the case of a zip'ed repo is because p2 treats it as a non-local repo and installs from the pack file which it finds. However when the repository is exploded on the file system, p2 first tries to download the JAR because the artifact repository index (artifacts.jar) indicates that it contains it even though it does not have it. If this reference had not been available in the artifact repo index, then p2 would have resorted to use the pack'ed files.
That said, the code in MirrorRequest#perform in the p2.artifact.repository bundle could be made for insistent and try every descriptor rather than just the first one.
Did you try to point the director app at the archive using as a repository the JAR URI (jar:file:/c:/archive.zip!/ or see the URI that gets created for you when you add the archive through the UI)?
HTH
PaScaL
Dalton, Tom
to:
p2-dev
09/10/2009 06:57 AM
Sent by:
Please respond to P2 developer discussions
I'm using the Eclipse 3.5 CDT on a non-networked machine and I want to add the EMF framework to it. I have downloaded the EMF update site .zip from
http://www.eclipse.org/modeling/emf/downloads/?project=emf
Specifically I got http://www.eclipse.org/modeling/download.php?file=/modeling/ emf/emf/downloads/drops/2.5.0/R200906151043/emf-xsd-Update-2 .5.0.zip
Now, if I install that update though the Eclipse UI by selecting the zip file itself, everything works. However, if I unzip the file to somewhere temporary and then try to install from that location, it gets to about 60% though and then bombs out with a mass of 'file not found' errors, because it seems to be looking for the plugins as plain .jar files instead of the actual .jar.pack.gz files.
This difference in behaviours seems to me to be a bug, albeit with a workaround (install direct from the zip rather than extracting it myself). So that would be fine, except that I need to automat the eclipse build (I need to add a lot more than just EMF and need to do this for a lot of people).
So I started looking at the P2 director command line stuff described at:
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/p2_director.html
And
http://wiki.eclipse.org/Equinox_p2_director_application#Inst alling_.2F_uninstalling_IUs_into_a_target_product
However, when using these methods, if I set the -repository to point at the zip file itself, it moans that its not a valid repository. If I point it at my manually unzipped directory, it starts off ok, but then bombs out with the same file not found errors as described above.
So two questions:
1. Are these file not found errors the symptoms of a bug?
2. Is there a way to duplicate the UI install-from-zip behaviour via the command line P2 director (which would provide me with a solution to my problem).
Thanks a lot for any help provided!
Tom Dalton _______________________________________________
p2-dev mailing list
p2-dev@eclipse.org
https://dev.eclipse.org/mailman/listinfo/p2-dev
FUDForum. Page generated in 0.01787 seconds
