Home » Eclipse Projects » Platform - User Assistance (UA) » Context Sensitive Help problems
| Context Sensitive Help problems [message #483918] |
Thu, 03 September 2009 11:13  |
Chris Phelps Messages: 2 Registered: September 2009 |
Junior Member |
We are trying to develop context-sensitive help for our RCP application,
and are running into a number of issues. For some of our views, our
documentation is correct and functional. For others, however, we see a
variety of behaviors.
- One view produces the correct help content when it gains focus from
another view, but does not provide the correct help when you press F1 on
the view directly.
- Another view does not find content when F1'd, and shows the help
content from a previous view when it gains focus from that view. The
"About View Name" header is correct for this view, but the content remains
that of the previous view.
- Some of our malfunctioning views display the "Each workbench window
contains..." message, while others contain the "Click on any workbench
part..." message.
We have examined all the code for these plugins, and the help context
seems to be set correctly (the
PlatformUI.getWorkbench().getHelpSystem().setHelp() is called from the
view's createPartControl()). The context.xml and plugin.xml for the
documentation plugin seems correct and well-formed. Using the Plug-In
spy, the active help context ID matches up with the ID in the context.xml.
Finally, we have tried deploying this help plugin both in an Infocenter
and locally, and have tried both .jar format and as a folder structure.
In all cases, the behavior is similar.
Has anyone seen similar behaviors, or have any suggestions on other things
we should try?
Thanks very much
Chris
| Re: Context Sensitive Help problems [message #484666 is a reply to message #483918] |
Tue, 08 September 2009 12:53  |
Chris Goldthorpe Messages: 815 Registered: July 2009 |
Pressing F1 causes the help system to go through different code to that
which is taken when the view gets focus although they should have the
same result if the view has set help correctly. If help is displayed as
a result of a view focus event it will use the selected control as the
basis for determining the help context, and if the selected control does
not have a help context defined it will look at the parent control and
ancestor controls until a control is found which has help defined, or a
top level control is found.
What version of Eclipse are you using? The first problem sounds like a
focus issue, sometimes this is related to the setFocus() routine in the
view. The second issue is one where it appears to not be finding any
context help based on the control that has focus and is displaying stale
information. The display of stale information sounds the same as a bug
that was fixed so if you can try Eclipse 3.5 you may find that problem
no longer exists.
> the view directly.
> remains that of the previous view.
> part..." message.
> things we should try?
> Thanks very much
> Chris
| Re: Context Sensitive Help problems [message #623547 is a reply to message #483918] |
no longer exists.
> the view directly.
> part..." message.
> Thanks very much
> Chris
Current Time: Fri May 24 17:25:54 EDT 2013
Powered by FUDForum. Page generated in 0.01698 seconds
