Home » Eclipse Projects » EclipseLink » Database Schema
Database Schema [message #484481] Mon, 07 September 2009 12:06 Go to next message
Enrico is currently offline Enrico
Member
Dear all,
is it possible to specify on the persistence.xml the database shema that
tables refere to?
Somethinng like openjpa "openjpa.jdbc.schema" oer hibernate
"hibernate.default_schema".
BR,
Enrico
Re: Database Schema [message #484621 is a reply to message #484481] Tue, 08 September 2009 10:27 Go to previous message
James Sutherland is currently offline James Sutherland
EclipseLink does not currently have a persistence.xml property for this (please log a bug). But you can set this in the orm.xml, also you could set a SessionCustomizer in your persistence.xml and set this on the EclipseLink Session's DatabaseLogin (setTableQualifier).
James : Wiki : Book : Blog
Previous Topic:Use Transformer in query
Next Topic:Is TABLE_PER_CLASS supposed to work with eclipselink-2.0.0.v20090731-r4765 (m6)
Current Time: Sun May 26 02:15:08 EDT 2013
Powered by FUDForum. Page generated in 0.04761 seconds
