| NullPointerException in JBoss debug mode [message #484251] |
Fri, 04 September 2009 15:06 |
Originally posted by: bselu42.googlemail.com
I'm a bit desperate about the following problem. If I start my JBoss from
Eclipse normally, everything goes fine. If I stat it in debug mode though,
I get the following error message:
'JDI Event Dispatch' has encountered a problem.
An internal error occured during "JDI Event Dispatch".
See also: http://bselu.dyndns.org/JdiEventDispatchNPE.png
In the Error Log I find the corresponding StackTrace:
org.eclipse.jdt.internal.debug.core.breakpoints.JavaBreakpoi nt.installableReferenceType(JavaBreakpoint.java:373)
org.eclipse.jdt.internal.debug.core.breakpoints.JavaBreakpoi nt.handleClassPrepareEvent(JavaBreakpoint.java:331)
org.eclipse.jdt.internal.debug.core.breakpoints.JavaBreakpoi nt.handleEvent(JavaBreakpoint.java:271)
org.eclipse.jdt.internal.debug.core.EventDispatcher.dispatch (EventDispatcher.java:155)
org.eclipse.jdt.internal.debug.core.EventDispatcher.access$0 (EventDispatcher.java:104)
org.eclipse.jdt.internal.debug.core.EventDispatcher$1.run(Ev entDispatcher.java:250)
I have a fresh Eclipse 3.5 installed including JBoss Tools 3.1.0M. The
JBoss in use is 4.2.3.GA, but I also tried it with a 5.1.0.GA with the
same outcome. So I guess this is not the point. Furthermore I can
definitely start JBoss in debug mode from the command line. But I cannot
do it from Eclipse (it worked in the past).
Please make some light!
Best regard, Ecke
FUDForum. Page generated in 0.01518 seconds
