| Connector discovery - availability [message #483638] |
Wed, 02 September 2009 07:57  |
Originally posted by: david.balazic.hermes.si.foo
Hi!
The page
http://www.polarion.com/products/svn/subversive/connector_di scovery.php
talk about Connector discovery but it does not work on my setup.
After some inspection, I see the page says "... than it was in versions
before 0.7.8.I20090808-1900". I just installed Eclipse 3.5.0 Java EE IDE
and then the subversive plugin, which is the version
0.7.8.I20090506-1500 (and Update says there is no newer version).
Are the newer releases in some pre final stage (beta, etc...) ?
Where to get them? If they are not final, is it a good idea to use them
in production?
David
My email address has a spamers-confusing addition...
| Re: Connector discovery - availability [message #488255 is a reply to message #483638] |
Sat, 26 September 2009 18:36   |
james cook Messages: 2 Registered: July 2009 |
Junior Member |
I'm having similar problems, but i'm trying to move from 3.4 to 3.5 so it's an existing setup. I'm getting no svn related functionality- the <SVN Repository> explorer is empty and the projects have no svnnature -
The log shows ..
org.eclipse.team.core.TeamException: Could not instantiate provider org.eclipse.team.svn.core.svnnature for project.
I've tried numerous installs.
1. Via "Galileo" - Galileo - http://download.eclipse.org/releases/galileo and then Collaboration / Subversive and
2. as you mention above via the update URL you quote - http://download.eclipse.org/technology/subversive/0.7/update -site/
in both cases no connectors are loaded. I tried loading the connectors manually but always the same error in the .log shown above.
info:
Using the JEE version of eclipse ...
vista business .
!SESSION 2009-09-27 00:17:12.840 -----------------------------------------------
eclipse.buildId=I20090611-1540
java.version=1.6.0_15
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_CH
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product -debug
[Updated on: Sat, 26 September 2009 18:38] Report message to a moderator
FUDForum. Page generated in 0.09816 seconds
