Home » Eclipse Projects » Buckminster dev » RE: [buckminster-dev] create.eclipse.jnlp.product issues
RE: [buckminster-dev] create.eclipse.jnlp.product issues [message #483441] Tue, 01 September 2009 11:41
Eclipse User
Originally posted by: dieter.cailliau.barco.com
------_=_NextPart_001_01CA2B1A.9B0CC7C5
Content-Type: text/plain;
charset="iso-8859-1"
I succeeded in making a jnlp thing with both buckminster, and headless =
buckminster. The solution for (A) was unsigning all jars, the correct =
way to do so is with this ant-extension: =
http://code.google.com/p/existdb-contrib/wiki/ASOCAT=20
Then another problem arised: the generated =
org.eclipse.equinox.executable_3.3.200.v20090521-1800-7M-Fm- FI3UouOe61h3B=
YGC.jnlp has no jnlp/information/vendor node, and the jnlp-client =
therefore refuses to proceed. I simply had to add that node to get it =
working.
So here's my userguide to make a webstartable with buckminster:
make a releng-feature that includes all my code own, plus the =
eclipse.rcp, eclipse.platform, eclipse.equinox.executable and run =
create.eclipse.jnlp.product there.
in each *.jnlp remove the features/ prefix in the extension nodes.
remove reference to plugin/...wpf... jars in rcp.jnlp and =
equinox.executable jnlp's
remove reference to plugin/...compare.win32 in platform jnlp
add WEB-INF/web.xml and WEB-INF/lib/jnlp-servlet.jar in the war
add jnlp/information/vendor node in equinox.executable jnlp
unsign all plugin/*.jar via ant and =
sign all plugin/*.jar with own certificate
add a boot.jnlp =
( http://help.eclipse.org/stable/index.jsp?topic=3D/org.eclips e.platform.d=
oc.isv/guide/java_web_start.htm) in the war and make sure it refers to =
the correct launcher jar (version) and to the correct jnlp
DISCLAIMER:
Unless indicated otherwise, the information contained in this message is =
privileged and confidential, and is intended only for the use of the =
addressee(s) named above and others who have been specifically =
authorized to receive it. If you are not the intended recipient, you are =
hereby notified that any dissemination, distribution or copying of this =
message and/or attachments is strictly prohibited. The company accepts =
no liability for any damage caused by any virus transmitted by this =
email. Furthermore, the company does not warrant a proper and complete =
transmission of this information, nor does it accept liability for any =
delays. If you have received this message in error, please contact the =
sender and delete the message. Thank you.
Content-Type: application/ms-tnef;
name="winmail.dat"
eJ8+IgEPAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAEIgAcA GAAAAElQTS5NaWNy
b3NvZnQgTWFpbC5Ob3RlADEIAQ2ABAACAAAAAgACAAEEgAEAOQAAAFJFOiBb YnVja21pbnN0ZXIt
ZGV2XSBjcmVhdGUuZWNsaXBzZS5qbmxwLnByb2R1Y3QgaXNzdWVzADAVAQWA AwAOAAAA2QcJAAEA
EQApAAAAAgAmAQEggAMADgAAANkHCQABABEAKQAAAAIAJgEBCYABACEAAABB RkRCQjc1MjVGQjY2
NzREOUYwNTBFNkQ2QjNFQjk4QwB+BwEDkAYAQAwAADkAAAADACYAAAAAAAMA NgAAAAAAQAA5AMXH
DJsaK8oBHgA9AAEAAAAFAAAAUkU6IAAAAAACAUcAAQAAADIAAABjPUJFO2E9 UlRUO3A9QkFSQ087
bD1LTkRNRVgwMS0wOTA5MDExNTQxMDBaLTU3NTg5AAAAHgBJAAEAAAA5AAAA UkU6IFtidWNrbWlu
c3Rlci1kZXZdIGNyZWF0ZS5lY2xpcHNlLmpubHAucHJvZHVjdCBpc3N1ZXMA AAAAQABOACHH7cPf
KsoBHgBaAAEAAAAkAAAAYnVja21pbnN0ZXItZGV2LWJvdW5jZXNAZWNsaXBz ZS5vcmcAAgFbAAEA
AABlAAAAAAAAAIErH6S+oxAZnW4A3QEPVAIAAAAAYnVja21pbnN0ZXItZGV2 LWJvdW5jZXNAZWNs
aXBzZS5vcmcAU01UUABidWNrbWluc3Rlci1kZXYtYm91bmNlc0BlY2xpcHNl Lm9yZwAAAAACAVwA
AQAAACkAAABTTVRQOkJVQ0tNSU5TVEVSLURFVi1CT1VOQ0VTQEVDTElQU0Uu T1JHAAAAAB4AXQAB
AAAAEQAAAENhaWxsaWF1LCBEaWV0ZXIAAAAAAgFeAAEAAABIAAAAAAAAAIEr H6S+oxAZnW4A3QEP
VAIAAAAAQ2FpbGxpYXUsIERpZXRlcgBTTVRQAGRpZXRlci5jYWlsbGlhdUBi YXJjby5jb20AAgFf
AAEAAAAfAAAAU01UUDpESUVURVIuQ0FJTExJQVVAQkFSQ08uQ09NAAAeAGYA AQAAAAUAAABTTVRQ
AAAAAB4AZwABAAAAJAAAAGJ1Y2ttaW5zdGVyLWRldi1ib3VuY2VzQGVjbGlw c2Uub3JnAB4AaAAB
AAAABQAAAFNNVFAAAAAAHgBpAAEAAAAaAAAAZGlldGVyLmNhaWxsaWF1QGJh cmNvLmNvbQAAAB4A
cAABAAAAIwAAAGNyZWF0ZS5lY2xpcHNlLmpubHAucHJvZHVjdCBpc3N1ZXMA AAIBcQABAAAAIAAA
AAHKFqGsOyN+Fnc2REf7uDhJaVgt+soFDpIydgAPIcrHHgB0AAEAAAAiAAAA QnVja21pbnN0ZXIg
ZGV2ZWxvcGVyIGRpc2N1c3Npb25zAAAAHgAaDAEAAAARAAAAQ2FpbGxpYXUs IERpZXRlcgAAAAAe
AB0OAQAAADUAAABbYnVja21pbnN0ZXItZGV2XSBjcmVhdGUuZWNsaXBzZS5q bmxwLnByb2R1Y3Qg
aXNzdWVzAAAAAAIBCRABAAAARgQAAEIEAADQBgAATFpGdeSntdADAAoAcmNw ZzEyNeIyA0N0ZXgF
QQEDAff/CoACpAPkBxMCgA/zAFAEVj8IVQeyESUOUQMBAgBjaOEKwHNldDIG AAbDESX2MwRGE7cw
EiwRMwjvCfe2OxgfDjA1ESIMYGMAUDMLCQFkMzYWUAumIEk0IHMa0GMJ4AEA ZCAVC4AgAMBrC4Bn
IGEAIGpubHAgdGh3HhID8B7AIAbgH0Ia0GtKbQuAcw6wciweQG7BHZBoZWFk bAeQBCBxH8kuIFQg
0B0ABvB1NHRpAiAgAhAFwChBqikfEGEEIHUAgWcDAPUeImwDIGoT8SBwHsAi UFsFoRggYwVAI4B5
HrBv/CBkJhAicB2gBCAfIx7B8wQgAHB0LQ7BCfAAkAIghjogwAJAcDovLwWg QQEALmdvb2chEC5h
BaBtL3AvDsAEAHQ4ZGItBaACMAUQYi8DA/AeAC9BU09DQf5UCuMKhAqAIjED oABwH4HNEoFwA2AC
YGVtHkAFEG0UEGQoMCUCZwnwBJBhpw6wHZAFsGcuBZBsBSCTFBAvQHF1C4Bv eC9AHngFkCKgAaAh
EF8zLiMxAAHQMC52MUE5MCEOQDEtMTgxUC03EE0tRm0ykEkzVQEIYE9lNjFo M0LwWUdDLh5zE+AE
ICzAPR5jLwuAIwEAwCKyL3b/CfAmMAXALMABACB0JQIecv8qUC9wCfAFQCzi ARAFsCJQ/TfxdRQQ
BCAmAS0xHUIiEP8c8QdwC1Al4BPgNqEmECDw/zaiLsA2EyXyLnAFQB8wHxBr BbAeAi4rqlMmEDfS
J/0EIG0l4DiRLyAv8DtUHeHjIlAeUHdlYiAwCsAwo/sfFR/YOiuqPwUYICEQ HiD0LWYg4HQIcDth
OvILgP0vYHUBACdBJHE+ASjCLwB8d24gcAtQOJAk8y9Wcv8N8CBwL1YLUQAw NSFGqC/f+z8xIKFy
I8AlMBggLsEvR/ceckcwA2BkGtA3pTyVHbHzIOAT0CAqM9QYIARgNbAzJPNC 9XMvLSEBEGl47x2i
RbMntjYTczyVTYU38S834UPQO2NFYWcLgC8u8VLAd3BmUsEkkx2iRnH/M9Qg kkhvNuQ90FC/Uc9S
wM8pgQqxKPAD8G4zFEAdsQ9HRh5jK6Q6oldFQi0YSU5GKtA/gC54bX8DICCS WwZIACrANwM+QXa9
IRB0M9AKwU9FI4ByWmj/NK81uR2iVL825CukI8QkU/dSVU0RCsF2BzAnUiCE KG//KX8qjyukY09d
wx8jRRElMPcEkCKwTwBjLsFaaB5QBuD7H4Az1ChlZSDQSyFH5i8RPi8/oS1h X5EBADAwanOUcD8m
AHAN4D0vLxolR0YuJjBjLgQAdi9DPnNc8GF2YV8/cV/1P6MuZWBtI2BeGCCD PwP/HRA4MTvxVxM4
wyUKC2AjwPcT0BKBXdIoNbAUACLBI2AXNoN1zFoofXnwAAAeADUQAQAAAD4A AAA8MDI4QUU4QTdD
MDRFRTE0ODg5QkU5OUU1NDUwQkUzMkQwMzZFQkFCNUBrbmRtZXgwMS5iYXJj by5jb20+AAAAHgA5
EAEAAAB8AAAAPDAyOEFFOEE3QzA0RUUxNDg4OUJFOTlFNTQ1MEJFMzJEMDM2 RUJBOTRAa25kbWV4
MDEuYmFyY28uY29tPiA8MDI4QUU4QTdDMDRFRTE0ODg5QkU5OUU1NDUwQkUz MkQwMzZFQkFBRkBr
bmRtZXgwMS5iYXJjby5jb20+AB4ARxABAAAADwAAAG1lc3NhZ2UvcmZjODIy AAALAPIQAQAAAB8A
8xABAAAAfgAAAFIARQAlADMAQQAgAFsAYgB1AGMAawBtAGkAbgBzAHQAZQBy AC0AZABlAHYAXQAg
AGMAcgBlAGEAdABlAC4AZQBjAGwAaQBwAHMAZQAuAGoAbgBsAHAALgBwAHIA bwBkAHUAYwB0ACAA
aQBzAHMAdQBlAHMALgBFAE0ATAAAAAAACwD2EAAAAABAAAcwvokpfBgrygFA AAgwf4wRmxorygED
AN4/r28AAAMA8T8JBAAAHgD4PwEAAAARAAAAQ2FpbGxpYXUsIERpZXRlcgAA AAACAfk/AQAAAEQA
AAAAAAAA3KdAyMBCEBq0uQgAKy/hggEAAAAAAAAAL089QkFSQ08vT1U9QUcw MDEvQ049UkVDSVBJ
RU5UUy9DTj1ESUVDAB4A+j8BAAAAFQAAAFN5c3RlbSBBZG1pbmlzdHJhdG9y AAAAAAIB+z8BAAAA
HgAAAAAAAADcp0DIwEIQGrS5CAArL+GCAQAAAAAAAAAuAAAAAwD9P+QEAAAD ABlAAAAAAAMAGkAA
AAAAAwAdQAAAAAADAB5AAAAAAB4AMEABAAAABQAAAERJRUMAAAAAHgAxQAEA AAAFAAAARElFQwAA
AAAeADJAAQAAACQAAABidWNrbWluc3Rlci1kZXYtYm91bmNlc0BlY2xpcHNl Lm9yZwAeADNAAQAA
ABoAAABkaWV0ZXIuY2FpbGxpYXVAYmFyY28uY29tAAAAHgA4QAEAAAAFAAAA RElFQwAAAAAeADlA
AQAAAAIAAAAuAAAAAwB2QP////8LACkAAAAAAAsAIwAAAAAAAwAGEEFlyRwD AAcQowQAAAMAEBAA
AAAAAwAREAAAAAAeAAgQAQAAAGUAAABJU1VDQ0VFREVESU5NQUtJTkdBSk5M UFRISU5HV0lUSEJP
VEhCVUNLTUlOU1RFUixBTkRIRUFETEVTU0JVQ0tNSU5TVEVSVEhFU09MVVRJ T05GT1IoQSlXQVNV
TlNJR05JTkdBAAAAAAIBfwABAAAAPgAAADwwMjhBRThBN0MwNEVFMTQ4ODlC RTk5RTU0NTBCRTMy
RDAzNkVCQUI1QGtuZG1leDAxLmJhcmNvLmNvbT4AAAApMg==
------_=_NextPart_001_01CA2B1A.9B0CC7C5--
Previous Topic:RE: [buckminster-dev] create.eclipse.jnlp.product issues
Next Topic:Bucky Book 0.6
Current Time: Sun May 19 06:54:12 EDT 2013
Powered by FUDForum. Page generated in 0.01466 seconds
