| 'Create obfuscated package' doen't include resource [message #482797] |
Thu, 27 August 2009 23:21  |
Originally posted by: wahid.sadik.gmail.com
I am using Pulsar, Build id: 20090619-0625.
When I try to build a MIDlet Project via 'Create obfuscated package', it
does not include files from the 'res' directory.
On the Application Descriptor, on the Build tab, even if I include the
'res' directory, it doesn't hold the values after saving the application
descriptor.
On the side note, when I add MTJ plugin on regular Eclipse, these
functions work just as expected.
Best Regards,
Wahid Sadik
| Re: 'Create obfuscated package' doen't include resource [message #482882 is a reply to message #482797] |
Fri, 28 August 2009 08:48   |
David Marques Messages: 80 Registered: July 2009 |
Member |
Hi Wahid,
The problem you are reporting was a bug on mtj version that was released
with your pulsar version. Current mtj version has fixed this issue, so
please update your mtj plugins within your pulsar version.
Best Regards,
David Marques
Wahid Sadik wrote:
> descriptor.
> Best Regards,
> Wahid Sadik
| Re: 'Create obfuscated package' doen't include resource [message #483008 is a reply to message #482882] |
Sat, 29 August 2009 04:25  |
Hi David,
Thank you so much for pointing out the solution. It directed me to the
right direction.
I already had MTJ 1.0.1 stable version installed. To nail the problem, I
recreated my project again (just copied src and res folders), and tried
the build. Everything worked just fine.
Thanks again for your prompt feedback.
Have a nice weekend!
Best Regards
Wahid Sadik
| Re: 'Create obfuscated package' doen't include resource [message #574194 is a reply to message #482797] |
Member |
Hi Wahid,
Best Regards,
David Marques
Wahid Sadik wrote:
> descriptor.
> Best Regards,
> Wahid Sadik
| Re: 'Create obfuscated package' doen't include resource [message #574250 is a reply to message #482882] |
Hi David,
right direction.
Best Regards
Wahid Sadik
FUDForum. Page generated in 0.09710 seconds
