Home » Eclipse Projects » BIRT » Catching (and explaining to end user) BIRT exceptions
Catching (and explaining to end user) BIRT exceptions [message #482987] Fri, 28 August 2009 17:54 Go to next message
Eclipse User
Originally posted by: l.arzeni.gmail.com
Hi to all,
environment: Eclipse 3.4, BIRT 2.5
I'm developing a standalone application for rendering report.
All works fine, problem arise when I need to explain problems to end user.
For example, if I use a wrong password for the oda connection, I can catch
the error, but this is not much meaningful.
Code example:
try {
IReportRunnable l_reportRunnable = m_engine.openReportDesign(i_reportPath);
catch (EngineException l_exception) {
l_exception.printStackTrace();
Exception printed is:
--- stdout begin ---
org.eclipse.birt.report.engine.api.EngineException: Error happened while
running the report at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:196)
....omissis...
Caused by: java.lang.NoClassDefFoundError: org/w3c/tidy/Tidy
org.eclipse.birt.report.engine.parser.HTMLTextParser.<init>(HTMLTextParser.java:55)
....omissis...
--- stdout end ---
But the real error is explained in the BIRT log:
--- log begin ---
Aug 28, 2009 9:04:57 PM
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
SEVERE: Cannot open connection.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in
get connection, FATAL: password authentication failed for user "timesheet".
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:229)
....omissis...
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask doRun
SEVERE: Error happened while running the report.
--- log end ---
So, (apart from the java.lang.NoClassDefFoundError: org/w3c/tidy/Tidy that I
don't understand), the real problem is known to BIRT: password
authentication failed, but from the code I can only report to the user that
there is an error while running the report (which is much less
explicative).
So question is: Is there any way to hook these problems at their origin? Is
there any way to hook BIRT error handler?
Thanks, Luca
Re: Catching (and explaining to end user) BIRT exceptions [message #483279 is a reply to message #482987] Mon, 31 August 2009 16:36 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Luca,
catch on all Exception intsances instead of just EngineException.
Also you can also check the errors:
if ( !task.getErrors( ).isEmpty( ) )
for ( Object e : task.getErrors( ) )
( (Exception) e ).printStackTrace( );
Jason
Luca Arzeni wrote:
> Hi to all,
> Code example:
> try {
> ...omissis...
> at
> ...omissis...
> --- stdout end ---
> --- log begin ---
> at
> ...omissis...
> at
> --- log end ---
> explicative).
> Thanks, Luca
Jason Weathersby
BIRT Exchange
Re: Catching (and explaining to end user) BIRT exceptions [message #483342 is a reply to message #483279] Tue, 01 September 2009 04:41 Go to previous message
Eclipse User
Thanks Jason, it did it!!!
Jason Weathersby wrote:
> Luca,
> Jason
> Luca Arzeni wrote:
>> Hi to all,
>> user. For example, if I use a wrong password for the oda connection, I
>> can catch the error, but this is not much meaningful.
>> Code example:
>> try {
>> ...omissis...
>> at
>> ...omissis...
>> --- stdout end ---
>> --- log begin ---
>> "timesheet".
>> at
>> ...omissis...
>> at
>> --- log end ---
>> that I don't understand), the real problem is known to BIRT: password
>> that there is an error while running the report (which is much less
>> explicative).
>> Is there any way to hook BIRT error handler?
>> Thanks, Luca
Previous Topic:Supressing Error Messages
Next Topic:Two series with different corresponding axis values on the same chart?
Current Time: Sat May 25 18:01:04 EDT 2013
Powered by FUDForum. Page generated in 0.01695 seconds
