Home » Eclipse Projects » Eclipse Platform » Setting Cursor Position in TextEditor
Setting Cursor Position in TextEditor [message #482510] Wed, 26 August 2009 16:29 Go to next message
Seth is currently offline Seth
I would like to set the cursor position in a class which extends
TextEditor.
This is how i tried to do this:
public void setOffset(int offset) {
setHighlightRange(offset,0,true);
I thought that eclipse that a highlight length of '0' would simply be
considered a cursor movement. Sometimes it works, but at other times it
doesn't. If i cincrease the length (middle arg), it also only works
sometimes. At other times, the cursor will not move. Looking at the code
of the setHighlightRange, it appears to call
fSourceViewer.setVisibleRegion(offset, length)
where fSourceView is an ISourceViewer. Setting the visible region does not
appear to be what i want....
Any ideas.
Thanks!
Re: Setting Cursor Position in TextEditor [message #482655 is a reply to message #482510] Thu, 27 August 2009 08:51 Go to previous message
Dani Megert is currently offline Dani Megert
> TextEditor.
See: org.eclipse.ui.texteditor.ITextEditor.selectAndReveal(int, int).
Dani
> considered a cursor movement.Sometimes it works, but at other times it
> code of the setHighlightRange, it appears to call
> not appear to be what i want....
> Any ideas.
> Thanks!
Previous Topic:Multiple Key Bindings to Single Action
Next Topic:TimeZone.getDefault() returns GMT
Current Time: Wed May 22 08:49:26 EDT 2013
Powered by FUDForum. Page generated in 0.02325 seconds
