Home » Eclipse Projects » Standard Widget Toolkit (SWT) » tabs are not drawn
tabs are not drawn [message #479908] Wed, 12 August 2009 23:30 Go to next message
Jason Hocker is currently offline Jason Hocker
Member
I have a client whose tabs are not being drawn... there are holes in the
program and can see right down to their desktop. This is for tabs on views,
editors, and even the tabs that make up a multi-page editor.
Windows XP 32-bit
Re: tabs are not drawn [message #480027 is a reply to message #479908] Thu, 13 August 2009 09:41 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric Rizzo
> Windows XP 32-bit
Just a shot in the dark, but...
By any chance does that user have his Windows GUI set to "classic" mode
where it looks like an old NT or Win95 UI? I've seen some very odd
behavior from SWT on XP when classic GUI mode is enabled.
Hope this helps,
Eric
Re: tabs are not drawn [message #481582 is a reply to message #479908] Fri, 21 August 2009 12:26 Go to previous message
Grant Gayed is currently offline Grant Gayed
I've heard of something like this in the past, but it should have been
fixed. Do you know what eclipse version is being used, and if it's old, can
3.5 be tried?
Grant
"Jason Hocker" <jkh@datatel.com> wrote in message
news:h601dd$nvr$1@build.eclipse.org...
views,
> Windows XP 32-bit
Previous Topic:Drag selection image
Next Topic:Re: Bizarre issue with tab order in a ToolBar
Current Time: Sun May 26 04:05:35 EDT 2013
Powered by FUDForum. Page generated in 0.05312 seconds
