Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Print swt widgets
Print swt widgets [message #481092] Wed, 19 August 2009 11:06
Jordan Borisov is currently offline Jordan Borisov
I'm working on a java project and I have to print a document. The problem
is that the printer is black and white and it doesn't print any light
colors such as group box borders.Can you give me an advise how to print
swt widget with an aspect ratio of 1:1 in relation to the monitor.Our idea
is to build a composite and use the widget print method to print it and
its children.
P.S.
We are already write the composite on an image and print it with a desired
scale, but it doesn't the group box borders.
Best regards Jordan Borisov and Anton Georgiev
Previous Topic:Eclipse 3.5 Javascript-to-Java implementation document
Next Topic:Multi column combobox
Current Time: Sun May 19 21:04:45 EDT 2013
Powered by FUDForum. Page generated in 0.01624 seconds
