Home » Modeling » GMF (Graphical Modeling Framework) » java.lang.OutOfMemoryError: PermGen space
java.lang.OutOfMemoryError: PermGen space [message #481089] Wed, 19 August 2009 11:02 Go to next message
Milan Milanovich is currently offline Milan Milanovich
I created one simple domain model, gmf graph and mapping model, and when I
run my application, create a digram and try to put one element on it, I
get:
Exception in thread "org.eclipse.jface.text.reconciler.MonoReconciler"
btw - I'm using latest Eclipse Modeling Galileo.
Re: java.lang.OutOfMemoryError: PermGen space [message #481097 is a reply to message #481089] Wed, 19 August 2009 11:41 Go to previous messageGo to next message
Alexander Shatalin is currently offline Alexander Shatalin
Hello Milan,
Use -XX:MaxPermSize= jvm parameter to increase memory size used.
Alex Shatalin
Re: java.lang.OutOfMemoryError: PermGen space [message #481173 is a reply to message #481097] Wed, 19 August 2009 19:40 Go to previous message
Eclipse User
Originally posted by: johan.harjono.utoronto.ca
Also, if the PermGen error still persists even after you tried Alex's
fix. Try just using Eclipse for plugin developers and install GMF
manually. That worked for me :)
Johan
Alex Shatalin wrote:
> Hello Milan,
> Alex Shatalin
Previous Topic:Copy/Paste between files
Next Topic:Cut Copy Paste
Current Time: Tue May 21 02:54:22 EDT 2013
Powered by FUDForum. Page generated in 0.01722 seconds
