Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » Avoid showing errors in editor that are caused because of preprocessing directives
Avoid showing errors in editor that are caused because of preprocessing directives [message #480749] Tue, 18 August 2009 07:57 Go to next message
David Lucena is currently offline David Lucena
Member
Hi. My name's David. I recently started using MTJ, and as I needed the preprocessor, I developed some code including directives. The build tree shows no errors, and I can launch the Midlet without a problem because no real errors exist when the code is already preprocessed.
The problem arises in code editor windows. Seems that the code there is trying to be compiled in search of correctness before it is preprocessed.
Is there a way to make eclipse editor windows be affected with the preprocessor from MJT so that this kind of "phantom errors" are not shown?
Thank you in advance.
[Updated on: Tue, 18 August 2009 07:57]
Report message to a moderator
Re: Avoid showing errors in editor that are c aused because of preprocessed directives [message #480780 is a reply to message #480749] Tue, 18 August 2009 09:03 Go to previous messageGo to next message
David Marques is currently offline David Marques
Member
Hi David,
Unfortunately due to some JDT constraints it is not possible yet. Please
see thread
( http://dev.eclipse.org/mhonarc/lists/dsdp-mtj-dev/msg01287.h tml).
Best Regards,
David Marques
Re: Avoid showing errors in editor that are c aused because of preprocessed directives [message #480873 is a reply to message #480780] Tue, 18 August 2009 14:13 Go to previous messageGo to next message
Member
With "not possible yet" do you mean that it is not impossible, and eventually someone will kick in to make the changes? Am I correct?
Thanks.
David Marques wrote on Tue, 18 August 2009 09:03
Hi David,
see thread
Best Regards,
David Marques
Re: Avoid showing errors in editor that a re c aused because of preprocessed directives [message #480885 is a reply to message #480873] Tue, 18 August 2009 14:49 Go to previous message
Member
Hello Again David,
Yes, you are right. It is necessary to analyze the problem deeply and
propose a solution to fulfill this requirement to the JDT team.
Best Regards,
David Marques
> Thanks.
>> Hi David,
>> see thread
>> Best Regards,
>> David Marques
Re: Avoid showing errors in editor that are c aused because of preprocessed directives [message #575869 is a reply to message #480780] Tue, 18 August 2009 14:13 Go to previous message
Member
Thanks.
> Hi David,
> see thread
> Best Regards,
> David Marques
Re: Avoid showing errors in editor that a re c aused because of preprocessed directives [message #575888 is a reply to message #480873] Tue, 18 August 2009 14:49 Go to previous message
Member
Hello Again David,
Best Regards,
David Marques
> Thanks.
>> Hi David,
>> see thread
>> Best Regards,
>> David Marques
Previous Topic:Avoid showing errors in editor that are caused because of preprocessed directives
Next Topic:Problems with Motorola device
Current Time: Mon May 20 10:46:03 EDT 2013
Powered by FUDForum. Page generated in 0.03291 seconds
