Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Eclipse 3.5 Javascript-to-Java implementation document
Eclipse 3.5 Javascript-to-Java implementation document [message #480093] Thu, 13 August 2009 15:12 Go to next message
Eclipse User
Originally posted by: chenbeth.hotmail.com
Is there a document or Eclipse bug report that details how the javascript to
java ( and java to javascript ) is been implemented in Eclipse 3.5? I only
found javadoc for BrowserFuntion.
Thanks for any help.
-Beth
Re: Eclipse 3.5 Javascript-to-Java implementation document [message #480305 is a reply to message #480093] Fri, 14 August 2009 17:05 Go to previous messageGo to next message
Pan Daoen is currently offline Pan Daoen
take a look to org.eclipse.help/livehelp.js
Gr8vyguy
Beth Chen 写道:
> -Beth
Re: Eclipse 3.5 Javascript-to-Java implementation document [message #480560 is a reply to message #480093] Mon, 17 August 2009 11:55 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
There isn't a document for this, and there isn't a patch that contains all
of the changes (the bug report was
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156276 ). It was a pretty big
change, is there anything in particular you want to know? Much of the
low-level implementation can be found in:
for IE: class WebSite methods Invoke(), convertToJS(), convertToJava(),
GetExternal()
for Mozilla: class External (all), file external.idl/.xpt
for Safari: class Safari methods callJava(), convertToJS(), convertToJava(),
isSelectorExcludedFromWebScript(), webScriptNameForSelection()
Grant
"Beth Chen" <chenbeth@hotmail.com> wrote in message
news:h61ok2$77v$1@build.eclipse.org...
to
> -Beth
Re: Eclipse 3.5 Javascript-to-Java implementation document [message #480882 is a reply to message #480560] Tue, 18 August 2009 14:15 Go to previous message
Eclipse User
Grant, thanks for the information !
-Beth
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:h6buh5$ssm$1@build.eclipse.org...
> big
> GetExternal()
> convertToJava(),
> Grant
> to
>> only
>> Regards,
>> -Beth
Previous Topic:Library to extract frames from AVI files
Next Topic:Print swt widgets
Current Time: Sun May 19 16:43:54 EDT 2013
Powered by FUDForum. Page generated in 0.01939 seconds
