Home » Eclipse Projects » Eclipse Platform » [CVS] creating a branch from an od tag
[CVS] creating a branch from an od tag [message #480557] Mon, 17 August 2009 11:42 Go to next message
Eclipse User
Originally posted by: none.domain.invalid
Hi, is it possible, using eclipse to start a branch from an old tag
(older than the HEAD) ?
Re: [CVS] creating a branch from an od tag [message #480578 is a reply to message #480557] Mon, 17 August 2009 13:14 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric Rizzo
I think you can just load the code base from that tag using Replace With
> Another Branch or Version..., expand the Versions section to find the
tag you want (might have to use the Refresh Tags button).
Once you've loaded the tag you want, I think you can do a branch from there.
Hope this helps,
Eric
Re: [CVS] creating a branch from an od tag [message #480687 is a reply to message #480578] Tue, 18 August 2009 04:34 Go to previous message
Eclipse User
> there.
Thanks, i did a test, and it worked (now i have a "bTest" branch...).
Previous Topic:[galileo] "Unsatisfied version constraint" error
Next Topic:How to debug "No more handles" in my IDE
Current Time: Tue May 21 05:11:49 EDT 2013
Powered by FUDForum. Page generated in 0.07613 seconds
