Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Wrap Label
Wrap Label [message #480511] Mon, 17 August 2009 08:45 Go to next message
Chris Turner is currently offline Chris Turner
I Everyone,
I'm trying to build a Wizard but i'm having problems with the wright
Layout and the Label warping. I want to Show a Label in an Groupbox the
wraps around when it reaches the end of the GroupBox. Now it only gets cut
if it reches the end and the text is not wraped.
Here is my code.
Group g1=new Group(composite, SWT.NONE);
g1.setLayout(new RowLayout(SWT.VERTICAL));
g1.setLayoutData(new RowData(300,120));
g1.setText("Bla");
g1.setSize(300,150);
Label l1= new Label(g1, SWT.WRAP);
l1.setText("~ Some long text ~");
l1.setSize(300,120);
g1.pack();
It would be nice if anybody could point out my error.
Thanks in advance
Chris
Re: Wrap Label [message #480529 is a reply to message #480511] Mon, 17 August 2009 10:22 Go to previous message
Remo Loetscher is currently offline Remo Loetscher
Hi Chris,
Setting a RowData-Object on the label should solve your wrapping problem:
public class LabelWrapping {
LabelWrapping() {
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new RowLayout(SWT.VERTICAL));
int width = 300, height = 150;
Group g1 = new Group(shell, SWT.NONE);
RowLayout rowLayout = new RowLayout(SWT.VERTICAL);
g1.setLayout(rowLayout);
g1.setLayoutData(new RowData(width, height));
g1.setText("Bla");
Label l1 = new Label(g1, SWT.WRAP);
l1.setLayoutData(new RowData(width - (rowLayout.marginLeft +
rowLayout.marginRight), SWT.DEFAULT));
l1.setText("~ Some long text ~ ~ Some long text ~ ~ Some long text ~ ~
Some long text ~ ~ Some long text ~ ~ Some long text ~");
shell.setSize(350, 250);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
new LabelWrapping();
hth,
Remo
Chris Turner wrote:
> I Everyone,
> cut if it reches the end and the text is not wraped.
> Here is my code.
> g1.setText("Bla");
> g1.pack();
> Thanks in advance
> Chris
Previous Topic:readAndDispatch Causing Hang With Browser
Next Topic:newbie question
Current Time: Mon Jun 17 23:40:55 EDT 2013
Powered by FUDForum. Page generated in 0.01619 seconds
