| Conflicting query [message #480525] |
Mon, 17 August 2009 10:17  |
Originally posted by: purjopoa.spray.se
I have a web app that stopped working with the following error a few days
ago. I can't see what might cause the error. I have confirmed that the
query in the error message is not duplicated in queries.xml.
If I remove the query VstgJobScopeDescription.deleteAll I will get an
identical error message but with another query. If I remove that one,
again I get an identical error message with a third query etc etc...
Anyone got a clue??
Caused by: Exception [EclipseLink-7092] (Eclipse Persistence Services -
1.1.2.v20090612-r4475):
org.eclipse.persistence.exceptions.ValidationException
Exception Description: Cannot add a query whose types conflict with an
existing query. Query To Be Added:
[DeleteAllQuery(name="VstgJobScopeDescription.deleteAll"
referenceClass=VstgJobScopeDescription jpql="DELETE FROM
VstgJobScopeDescription")] is named: [VstgJobScopeDescription.deleteAll]
with arguments [[]].The existing conflicting query:
with arguments: [[]].
org.eclipse.persistence.exceptions.ValidationException.exist ingQueryTypeConflict(ValidationException.java:878)
org.eclipse.persistence.internal.sessions.AbstractSession.ad dQuery(AbstractSession.java:374)
org.eclipse.persistence.internal.sessions.AbstractSession.ad dQuery(AbstractSession.java:346)
org.eclipse.persistence.internal.sessions.AbstractSession.pr ocessJPAQueries(AbstractSession.java:1691)
org.eclipse.persistence.internal.sessions.DatabaseSessionImp l.initializeDescriptors(DatabaseSessionImpl.java:409)
org.eclipse.persistence.internal.sessions.DatabaseSessionImp l.postConnectDatasource(DatabaseSessionImpl.java:666)
org.eclipse.persistence.internal.sessions.DatabaseSessionImp l.login(DatabaseSessionImpl.java:630)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:169)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManager(EntityManagerFactoryImpl.java:150)
com.ford.vcc.menupricing.command.impl.importer.CheckMessageN otImportedCommand.execute(CheckMessageNotImportedCommand.jav a:28)
com.ford.vcc.menupricing.command.AbstractCommandWrapper.exec ute(AbstractCommandWrapper.java:27)
com.ford.vcc.menupricing.command.ConditionalChain.execute(Co nditionalChain.java:104)
at org.apache.commons.chain.impl.ChainBase.execute(ChainBase.ja va:191)
com.ford.vcc.menupricing.command.ChainTraceDecorator.execute (ChainTraceDecorator.java:28)
FUDForum. Page generated in 0.01666 seconds
