Home » Modeling » OCL » Re: OCL closures implementation
| Re: OCL closures implementation [message #479154] |
Sun, 09 August 2009 17:20  |
Ed Willink Messages: 3185 Registered: July 2009 |
Hi Neil, Christian, Nicolas
I stumbled over the experimental closure() implementation a few days
ago. It seems interesting. I see this has been raised as OMG Issue
13944. The RTF committee is so busy that if we want to get this in
OCL 2.3 there are better chances if the submission is formatted ready
for inclusion in the RTF report.
I think the recursive specification difficulty can be easily cured by
using infinite recursion of a helper function and a set that makes
further recursion redundant.
After trying to use the closure iterator, I think that an object
iterator form of closure is more fundamental than the collection
iterator. This allows the start object to be included in the results, so
a root and all its kids would be returned by
root.closure(it | it.kids)
whereas all the kids could be returned by
root.kids->forall(kid | kid.closure(it | it.kids))->asSet()
The collection iterator is nonetheless useful allowing the shorter
root.kids->closure(it | it.kids)
An object iterator is of course a new concept and so might bypass the
specification in terms of iterate ordanance.
Do you think it worth appending an update to Issue 13944 along these lines?
Ed Willink
On Mon, 14 Jul 2008 15:59:16 -0400, Christian W. Damus wrote:
Hi, Neil,
Actually, the closure iterator isn't really syntactic sugar. The OCL
specification suggests (requires?) that for any iterator _expression_
that is added to the standard library (not sure what that means; the
question was raised as an issue), a specification of the iterator in
terms of existing iterators (or the iterate _expression_) be provided.
The closure iterator is recursive by nature, and I don't think that this
can be expressed using the iterate _expression_. At least, I haven't
tried very hard ;-)
The important stopping condition is the encountering of an object that
has already been added to the closure result collection before. This,
of course, is the classic means of dealing with recursion in cyclical
structures. The MDT implementation is roughly this:
1. Collect the body-_expression_ values on the original source collection
S into a new set R'.
--> initialize the over-all closure result R to this set R'
2. For new elements added to R in the previous pass (previous R' set),
collect the body-_expression_ values into a new set R'.
--> add these results to R
3. Repeat step 2 until R' has no results not already in R (i.e.,
R' - R is the empty-set)
AFAIK, closure was never raised as a requested capability in the OCL
specification. Perhaps we should raise an enhancement issue?
HTH,
Christian
On Mon, 2008-07-14 at 15:23 -0400, Neil wrote:
> I'm aware that closure is not defined in the spec for OCL 2. I'm not
> clear why it's missing - too hard to implement or just not considered at
> the time.
> Is the implementation in Eclipse syntactic sugar for some variant of an
> OCL recursive function with stopping criteria? Or is something more
> involved being done behind the curtain?
> I'm trying to use OCL in Eclipse to define queries over a graph-like
> data structure (with possibly circular relations). So far the closure
> operator works perfectly, but I want to clarify how it's doing this.
> thanks
> Neil Ernst
| Re: OCL closures implementation [message #479609 is a reply to message #479154] |
Tue, 11 August 2009 13:07   |
Christian W. Damus Messages: 551 Registered: July 2009 |
--=-tJlTyt6IJS2oHmrAjz4Q
Content-Type: text/plain
Hi, Ed,
Good point about the helper operation: I hadn't considered that the
formal definition of the closure() iterator could include additional
operations. Of course, it can!
I can think of a few arguments against the object iterator construct:
- it would be the first instance of its kind, a new language
construct.
It probably needs to be able to show that it cannot be implemented
by any other mechanism (such as collection iterator) to justify that
- the "." operator makes "closure" look like a model operation. An
"ocl"
prefix could help, but then it still looks like an operation, not an
iterator
- I'm not sure that it's a good idea to always include the initial
object
in the closure. It's easy enough to extend the expression to add it
(e.g., "root->closure(kids)->including(root)" ) than it is to extend
the
expression to remove it. In the latter case, e.g.,
"root->closure(kids)->excluding(root)" there's no way to know that
root shouldn't be in the closure because it was reached via a cycle
Note that the arrow operator coerces scalar values to singleton sets, so
you can do
root->closure(kids)
to get the closure of the kids association and, if necessary,
root->closure(kids)->including(kids)
to ensure that the result has the root, also. If this is a very common
case, it may justify an additional iterator, say
root->withClosure(kids)
that includes the starting collection.
Just $0.02 from a still-interested-though-somewhat-remote party :-)
Christian
> Regards
> Ed Willink
--------8<--------
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Ed,<BR>
<BR>
Good point about the helper operation: I hadn't considered that the formal definition of the closure() iterator could include additional operations. Of course, it can!<BR>
<BR>
I can think of a few arguments against the object iterator construct:<BR>
<BR>
- it would be the first instance of its kind, a new language construct.<BR>
It probably needs to be able to show that it cannot be implemented<BR>
by any other mechanism (such as collection iterator) to justify that<BR>
<BR>
- the "." operator makes "closure" look like a model operation. An "ocl"<BR>
prefix could help, but then it still looks like an operation, not an<BR>
iterator<BR>
<BR>
- I'm not sure that it's a good idea to always include the initial object<BR>
in the closure. It's easy enough to extend the expression to add it<BR>
(e.g., "root->closure(kids)->including(root) " ) than it is to extend the<BR>
expression to remove it. In the latter case, e.g.,<BR>
"root->closure(kids)->excluding(root) " there's no way to know that<BR>
root shouldn't be in the closure because it was reached via a cycle<BR>
<BR>
Note that the arrow operator coerces scalar values to singleton sets, so you can do<BR>
<BR>
root->closure(kids)<BR>
<BR>
to get the closure of the kids association and, if necessary,<BR>
<BR>
root->closure(kids)->including(kids)<BR>
<BR>
to ensure that the result has the root, also. If this is a very common case, it may justify an additional iterator, say <BR>
<BR>
root->withClosure(kids)<BR>
<BR>
that includes the starting collection.<BR>
<BR>
Just $0.02 from a still-interested-though-somewhat-remote party :-)<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
Ed Willink
</PRE>
</BLOCKQUOTE>
<BR>
--------8<--------
</BODY>
</HTML>
--=-tJlTyt6IJS2oHmrAjz4Q--
| Re: OCL closures implementation [message #479711 is a reply to message #479609] |
Wed, 12 August 2009 03:03   |
Hi Christian
Glad you're still here.
Your comments and an accidentally off-list discussion with Nicolas
Rouquette have helped me clarify my thoughts.
The practical implementation of closure is not closure; it is transitive
closure. closure would require some form of allInstances to discover a
domain over which to evaluate a predicate. So the new iterator should
probably be called transitiveClosure().
Whether transitive closure on objects or collections is more fundamental
is a chicken and egg argument. Both are useful and beauty is in the eye
of the beholder. The clinching argument to me for which is best is to
examine the lexical consequences. Imagine that both were available. Then
we have ample opportunity for
elems.transitiveClosure()
elems->transitiveClosure()
typos and confusion. Only one can be permitted.
If just object closure existed, the interaction with implicit collect
for collections would be nearly as confusing, so the collection wins for
lexical ergonomic reasons.
My more general definition using a helper routine is therefore:
The transitiveClosure iterator signature is very similar to iterate
transitiveClosure(<elem> : T, <acc> : C(T) = <acc-init> |
<expression-with-elem>)
where
<expression-with-elem> is an iterator body expression that may reference
<elem> and which returns a collection of type C(T).
<elem> is the name an optional iterator variable for use in
<acc> is the optional name of a result variable of type C(T)
<acc-init> is the optional initial value for <acc>.
The default result variable is an empty Set(T).
The invocation
roots->transitiveClosure(<elem> : T, <acc> : C(T) = <acc-init> |
is equivalent to invocation of a helper routine as
roots->uniqueNameXxx(<acc-init>)
where the synthesized uniqueNameXxx is one of
Set::uniqueNameXxx(uniqueNameYyy : Set(T)) : Set(T) {
iterate(<elem> : T, acc : Set(T) = uniqueNameYyy |
if acc->includes(<elem>) then acc
else let candidates : Set(T) = <expression-with-elem>
in candidates->uniqueNameXxx(acc->including(<elem>))
endif)
OrderedSet::uniqueNameXxx(uniqueNameYyy : OrderedSet(T)) : OrderedSet(T) {
iterate(<elem> : T, acc : OrderedSet(T) = uniqueNameYyy |
else let candidates : OrderedSet(T) = <expression-with-elem>
in candidates->uniqueNameXxx(acc->append(<elem>))
endif)
Bag::uniqueNameXxx(uniqueNameYyy : Bag(T)) : Bag(T) {
iterate(<elem> : T, acc : Bag(T) = uniqueNameYyy |
if acc->includes(<elem>) then invalid
else let candidates : Bag(T) = <expression-with-elem>
endif)
Sequence::uniqueNameXxx(uniqueNameYyy : Sequence(T)) : Sequence(T) {
iterate(<elem> : T, acc : Sequence(T) = uniqueNameYyy |
else let candidates : Sequence(T) = <expression-with-elem>
endif)
Introduction of the optional <acc-init> allows an 'object' iteration to
include itself in the initialiser for transitiveClosure of its elements.
Introduction of the optional <acc-init> allows the collection type to be
defined.
Support for OrderedSets provides a defined depth first ordering for such
transditiveClosures.
Support for Bags and Sequences is more dubious. The definitions above
give useful results for trees and invalid for graphs.
Ed Willink
> Hi, Ed,
> iterator
> (e.g., "root->closure(kids)->including(root)" ) than it is to extend the
> you can do
> root->closure(kids)
> Cheers,
> Christian
>> Regards
>> Ed Willink
> --------8<--------
| Re: OCL closures implementation [message #480025 is a reply to message #479711] |
Thu, 13 August 2009 09:48   |
--=-EYB6pwSphaIBGDKznzrM
Hi, Ed,
See some replies in-line, below.
Christian
On Wed, 2009-08-12 at 08:03 +0100, Ed Willink wrote:
> Hi Christian
That sounds more clear; good.
Oh, yes. The implicit collect is a very good point!
> where
> The invocation
I think the "iterate" syntax uses a semicolon to separate the
accumulator from the iterator variables, which are usually separated by
commas. The accumulator isn't an iterator variable, so it needs to be
set apart.
> endif)
> endif)
> endif)
> endif)
> defined.
That's different from other iterators, in which the resulting collection
kind generally is determined by the source collection kind. And I
wonder whether OCL really wants to have another iterator as complex as
the "iterate" expression, with accumulators and such. Don't get me
wrong, I like this idea of iterate-like syntax because it solves both of
these problems, but I wonder whether it's not over-kill.
OTOH, the recursive nature of this iterator is already very different
from other iterators: it iterates over more than just the source
collection! Really, quite a different beast.
Yes, repetition of elements doesn't seem very useful in a transitive
closure, which is really only interested in finding reachable objects.
The number of occurrences of any object would only be useful if the
result could indicate where they were found, which it doesn't.
> Regards
> Ed Willink
--------8<--------
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Ed,<BR>
<BR>
See some replies in-line, below.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Hi Christian
</PRE>
</BLOCKQUOTE>
<BR>
<PRE>
</PRE>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
Oh, yes. The implicit collect is a very good point!<BR>
<BR>
<BR>
<PRE>
where
The invocation
</PRE>
</BLOCKQUOTE>
<PRE>
</PRE>
I think the "iterate" syntax uses a semicolon to separate the accumulator from the iterator variables, which are usually separated by commas. The accumulator isn't an iterator variable, so it needs to be set apart.<BR>
<BR>
<BR>
<PRE>
in candidates->uniqueNameXxx(acc->including(& lt;elem>))
endif)
in candidates->uniqueNameXxx(acc->append(< elem>))
endif)
endif)
endif)
defined.
</PRE>
</BLOCKQUOTE>
<PRE>
</PRE>
That's different from other iterators, in which the resulting collection kind generally is determined by the source collection kind. And I wonder whether OCL really wants to have another iterator as complex as the "iterate" expression, with accumulators and such. Don't get me wrong, I like this idea of iterate-like syntax because it solves both of these problems, but I wonder whether it's not over-kill.<BR>
<BR>
OTOH, the recursive nature of this iterator is already very different from other iterators: it iterates over more than just the source collection! Really, quite a different beast.<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
Yes, repetition of elements doesn't seem very useful in a transitive closure, which is really only interested in finding reachable objects. The number of occurrences of any object would only be useful if the result could indicate where they were found, which it doesn't.<BR>
<BR>
<PRE>
Ed Willink
</PRE>
</BLOCKQUOTE>
<BR>
<PRE>
--------8<--------
</PRE>
</BODY>
</HTML>
--=-EYB6pwSphaIBGDKznzrM--
| Re: OCL closures implementation [message #480156 is a reply to message #480025] |
Fri, 14 August 2009 04:07   |
Hi Christian
Yes the more general solution is a rather more powerful beast that can
do much more than transitive closure.
I suspect the underlying recursive iterator should be called recurse
with transitiveClosure a simple invocation thereof. As a generic
recursive iterator there can be two 'accumulators' one initializable
only with an 'already visited set' that is maintained by the recursion,
the other 'acc' optionally allowing the recurse body to accumulate and
return user relevant values rather than the final 'already visited set'.
Ed Willink
> Hi, Ed,
> Cheers,
> Christian
>> Hi Christian
>> where
>> The invocation
> set apart.
>> endif)
>> endif)
>> endif)
>> endif)
>> defined.
>> Regards
>> Ed Willink
> --------8<--------
| Re: OCL closures implementation [message #480232 is a reply to message #480156] |
Fri, 14 August 2009 09:21  |
--=-qJZIVim53NpsyEBf3hnz
Hi, Ed,
That sounds even better. It would solve a great many common OCL
problems. Looks like a plan!
cW
On Fri, 2009-08-14 at 09:07 +0100, Ed Willink wrote:
> Hi Christian
> Regards
> Ed Willink
> > Hi, Ed,
> > Cheers,
> > Christian
> >> Hi Christian
> >> where
> >> The invocation
> > set apart.
> >> endif)
> >> endif)
> >> endif)
> >> endif)
> >> defined.
> >> Regards
> >> Ed Willink
> > --------8<--------
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Ed,<BR>
<BR>
That sounds even better. It would solve a great many common OCL problems. Looks like a plan!<BR>
<BR>
:-)<BR>
<BR>
cW<BR>
<BR>
<BR>
<PRE>
Hi Christian
Ed Willink
> Hi, Ed,
> Cheers,
> Christian
>> Hi Christian
>> where
>> The invocation
> set apart.
>> endif)
>> endif)
>> endif)
>> endif)
>> defined.
>> Regards
>> Ed Willink
> --------8<--------
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-qJZIVim53NpsyEBf3hnz--
Current Time: Sun May 26 00:40:45 EDT 2013
Powered by FUDForum. Page generated in 0.01788 seconds
