| SWTBot can't find the "File" menu [message #479947] |
Thu, 13 August 2009 04:11  |
Pierre-Charles David Messages: 40 Registered: July 2009 |
Member |
--------------030206060208010501050908
I've got a very strange issue and I don't know where to look for to fix
it. In some Eclipse configuration I use, SWTBot does not work at all: it
fails the very first method with a WidgetNotFoundException.
The test is org.eclipse.gef.example.logic.test.OpenGefEditor, from [1]
but it doesn't seem to be doing anything special.
Using one Eclipse installation it works perfectly. Using another, it
fails at the first SWTBot method. In both cases, this is under Windows
XP SP2, Java 1.6, but it looks like the behavior is the same under Linux.
- First configuration (where it works):
- Eclipse 3.5 Modeling Package
- SWTBot for SWT Testing 2.0.0.371-dev-e35
- SWTBot for Eclipse Testing 2.0.0.371-dev-e35
- SWTBot4Gef Feature 0.1.0.200907301531
In this configuration, the test works. I get a warning from log4j
because "No appenders could be found", but the test itself passes.
- Second configuration (where it fails)
- Topcased RCP 3.0.1 from [2]
- Same versions of SWTBot and SWTBot4Gef
In this configuration, the runtime Eclipse launches, I see the
welcome page, and then:
- when the code tries to access the Welcome view to close it =>
WidgetNotFoundException. It is normally ignored, but I've added a
printStackTrace() to confirm it is thrown.
- the test continues and tries a bot.menu("File"), which fails with a
timeout. The file menu is present in the Eclipse under test, which
itself is in focus.
What is even stranger is that in the second configuration, Log4J is
enabled and tells me repeatedly that it "matched MenuItem with text
"&File", using matcher: with mnemonic 'File" until the caller timeouts.
Apart for some preinstalled features and branding, Topcased RCP looks
very much like a standard Eclipse. It launches on a normal workbench,
with a Welcome page, and standard menus (include "File"). I attach the
logs I get while running the failing test and the final stack trace from
JUnit.
I have no idea about what difference in both configurations can cause
the problem. Any hint about where to look for?
Thanks.
[1]
http://code.google.com/p/swtbot4gef/source/browse/#svn/trunk /org.eclipse.swtbot4gef/examples
[2] http://www.topcased.org/index.php?idd_projet_pere=52&Ite mid=60
name="logs.txt"
Content-Disposition: inline;
filename="logs.txt"
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundExcep tion: Could not find widget.
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetA ppears(SWTBotFactory.java:346)
at org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot.view(SWTWo rkbenchBot.java:122)
at org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot.viewByTitl e(SWTWorkbenchBot.java:135)
at org.eclipse.gef.examples.logic.test.OpenGefEditorTest.closeW elcomePage(OpenGefEditorTest.java:35)
at org.eclipse.gef.examples.logic.test.OpenGefEditorTest.setUp( OpenGefEditorTest.java:29)
at junit.framework.TestCase.runBare(TestCase.java:132)
at org.eclipse.swtbot.swt.finder.SWTBotTestCase.runBare(SWTBotT estCase.java:228)
at junit.framework.TestResult$1.protect(TestResult.java:110)
at junit.framework.TestResult.runProtected(TestResult.java:128)
at junit.framework.TestResult.run(TestResult.java:113)
at junit.framework.TestCase.run(TestCase.java:124)
at junit.framework.TestSuite.runTest(TestSuite.java:232)
at junit.framework.TestSuite.run(TestSuite.java:227)
at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38Cla ssRunner.java:79)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:46)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:64)
at org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:117)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:71)
at java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find view matching: with name '"Welcome"'
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:396)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:370)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:358)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetA ppears(SWTBotFactory.java:344)
... 22 more
0 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
540 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
1041 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
1542 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
2043 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
2543 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
3054 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
3575 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
4076 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
4606 [main] DEBUG org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher - matched MenuItem with text "&File", using matcher: with mnemonic 'File'
5107 [main] DEBUG org.eclipse.swtbot.swt.finder.utils.SWTUtils - Capturing screenshot 'screenshots/screenshot-OpenGefEditorTest.testCreateFile.jpe g'
name="stacktrace.txt"
filename="stacktrace.txt"
at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFacto ry.java:255)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFacto ry.java:206)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.menu(SWTBotFacto ry.java:196)
at org.eclipse.gef.examples.logic.test.NewEmptyEmfProject.creat eProject(NewEmptyEmfProject.java:26)
at org.eclipse.gef.examples.logic.test.OpenGefEditorTest.testCr eateFile(OpenGefEditorTest.java:48)
at junit.framework.TestCase.runTest(TestCase.java:168)
at junit.framework.TestCase.runBare(TestCase.java:134)
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find a menu within the shell 'Shell with text {Shell {Resource - Eclipse P...}}' matching 'with mnemonic 'File''
... 28 more
--------------030206060208010501050908--
| Re: SWTBot can't find the "File" menu [message #480051 is a reply to message #479947] |
Thu, 13 August 2009 11:00  |
Member |
Pierre-Charles David a écrit :
[snip]
Well, I found the issue:
SWTBot declares a dependency to org.apache.log4j but does not indicate
any specific version. However, it uses APIs which only appeared in log4j
1.2.12 (at least Logger.trace(), maybe others).
In the Eclipse installation I have which did not work ("Topcased RCP"),
there was a bundle which provided the org.apache.log4j package, but
using log4j version 1.2.8. As it happens, Eclipse decided to provide
this one to SWTBot instead of other versions available from different
bundles (1.2.12 and 1.2.15). The test failed with an internal
NoSuchMethodError, which must have been caught by some code and wrapped
as the WidgetNotFoundException I saw.
Removing the plugin with log4j 1.2.8 from the test's run configuration
solves the issue.
I have opened bug #286527 about this.
FUDForum. Page generated in 0.01630 seconds
