Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Label with SWT.WRAP and SWT.CENTER is wrapped, but not centered (Mac OS X)
SWT Label with SWT.WRAP and SWT.CENTER is wrapped, but not centered (Mac OS X) [message #479073] Sat, 08 August 2009 17:30 Go to next message
Robert Retzbach is currently offline Robert Retzbach
I'm using Galileo Eclipse for RCP/Plug-in Developers (Build id:
20090619-0625) with Cocoa Support on Mac OS X 10.5.7 (Build 9j61) and
tried to center wrapped text of a Label.
As mentioned by rcjsuen in #eclipse at freenode this works on WinXP in
both Ganymede and Galileo. I checked and found out that Cocoa's multi line
labels support centered text that wraps. So I would assume that this might
be SWT bug.
Please analyse this issue. Thanks.
This is how it looks like:
http://img194.imageshack.us/img194/3346/bild18.png
This is how it should look like (created with xcode):
http://img196.imageshack.us/img196/7934/bild17a.png
Snippet to reproduce:
http://pastebin.com/f5b0ac349
Best regards
Robert
Re: SWT Label with SWT.WRAP and SWT.CENTER is wrapped, but not centered (Mac OS X) [message #479312 is a reply to message #479073] Mon, 10 August 2009 12:42 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric Rizzo
Robert Retzbach wrote:
> line labels support centered text that wraps. So I would assume that
> this might be SWT bug.
Please enter a bug about it and attach the snippet code. Good idea to
search for an existing bug, first.
http://bugs.eclipse.org/bugs/
Hope this helps,
Eric
Re: SWT Label with SWT.WRAP and SWT.CENTER is wrapped, but not centered (Mac OS X) [message #479703 is a reply to message #479073] Wed, 12 August 2009 02:09 Go to previous messageGo to next message
Peter Kanzler is currently offline Peter Kanzler
It should be already fixed in the newest 3.6 Build...
I reported it some time ago:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=276110
cheers
Peter
> Best regards
> Robert
Re: SWT Label with SWT.WRAP and SWT.CENTER is wrapped, but not centered (Mac OS X) [message #479851 is a reply to message #479703] Wed, 12 August 2009 13:24 Go to previous message
Thanks for the reference. I added a comment suggesting it be pushed into
3.5.1, due in a few weeks. Since it works correctly on other platforms
(and even in OS X Carbon), seems like something that should not have to
wait for a year.
Eric
>> Best regards
>> Robert
Previous Topic:Performance of setItemCount in SWT Tree
Next Topic:Spinner - Min, Max values
Current Time: Sat May 18 18:20:30 EDT 2013
Powered by FUDForum. Page generated in 0.01583 seconds
