| How to trigger upstream builders when downstream projects change [message #479833] |
Wed, 12 August 2009 12:20 |
Chris Gross Messages: 471 Registered: July 2009 |
I'm implementing a new project incremental builder. My projects have
dependencies. For example, I have two projects: projectA and
projectThatDependsOnA. I'm unsure how I should tell eclipse to rebuild
projectThatDependsOnA everytime projectA changes. I've setup the project
references and that helps with build ordering but it doesn't seem to
trigger the upstream builds as necessary.
I see that I can call something like IProject#build but this doesn't
appear to run in the background as a normal build.
TIA
-Chris
FUDForum. Page generated in 0.01484 seconds
