Home » Eclipse Projects » GEF » Editing capabilities with GEF in Eclipse View
Editing capabilities with GEF in Eclipse View [message #479789] Wed, 12 August 2009 09:48 Go to next message
Eclipse User
Originally posted by: pitbule.abv.bg
Hi all,
Is it possible to create an Eclipse View with editing capabilities
provided by GEF ( to act as editor but in a view )?
Re: Editing capabilities with GEF in Eclipse View [message #479792 is a reply to message #479789] Wed, 12 August 2009 10:23 Go to previous messageGo to next message
Pascal G is currently offline Pascal G
valeri111 wrote:
> Hi all,
The outline view is a good candidate to start with, since gef provide a
class to be embedded in the outline view (ContentOutlinePage). You can
do anything you'd do with an editor with it. However, it need to be
binded with an editor which will provide an instance of this class when
asked for a IContentOutlinePage through getAdapter(Class). Nevertheless,
it shows well that it is possible to create a view with editing
capabilities.
Other then the outline view, I think it could be pretty easy since
basically all you have to do is to set the control of the view with the
control of the gef viewer. I've never done this though...
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Editing capabilities with GEF in Eclipse View [message #481430 is a reply to message #479789] Thu, 20 August 2009 19:17 Go to previous message
René is currently offline René
Member
all you need to use GEF is an SWT Control...So you can use GEF with an
Eclipse View (ViewPart). Look at this example, that may help:
http://www.eclipse.org/gef/reference/digraph1.php#Digraph1Vi ew
René
valeri111 wrote:
> Hi all,
Previous Topic:[Zest] DirectedGraphLayoutAlgorithm - Nodes are not visible
Next Topic:Exception in thubnail generation for outline view
Current Time: Tue May 21 11:39:45 EDT 2013
Powered by FUDForum. Page generated in 0.01747 seconds
