Home » Eclipse Projects » Eclipse Platform » How to check Radio in Menu Contribution
How to check Radio in Menu Contribution [message #452317] Sat, 01 August 2009 08:56 Go to next message
Kai Schlamp is currently offline Kai Schlamp
Hi.
I programmatically added some commands by doing
LayoutResultGraphAction layoutResultGraphAction = new LayoutResultGraphAction();
service.activateHandler("org.pubcurator.core.commands.option1 ", new ActionHandler(Option1Action));
and added those as sub menus to a toolbar pulldown menu contribution as radio buttons.
They show up correctly, but I don't know how to check them when clicked.
A option1Action.setChecked(true) does nothing.
How do I do that?
Kai
Re: How to check Radio in Menu Contribution [message #452780 is a reply to message #452317] Sat, 01 August 2009 10:00 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
AFAIK it won't link up a toggle or radio action with a menu contribution.
To support toggle or radio menu contributions you need to write a handler
that can implement org.eclipse.ui.commands.IElementUpdater
It has a method that will be called for each UIElement, and supports
setChecked(*)
See:
http://wiki.eclipse.org/Menu_Contributions#Example_Matrix
The examples need to be updated to show they understand State support
(early activation is no longer necessary to maintain the checked state
across restarts).
PW
Re: How to check Radio in Menu Contribution [message #452864 is a reply to message #452780] Sat, 01 August 2009 10:07 Go to previous messageGo to next message
Thanks Paul.
I also just found that blog entry
http://blog.eclipse-tips.com/2009/03/commands-part-6-toggle- radio-menu.html
I think I will from now on directly use Handlers (I even don't know why I only used Actions until now).
Kai
> contribution. To support toggle or radio menu contributions you need to
> write a handler that can implement org.eclipse.ui.commands.IElementUpdater
> setChecked(*)
> See:
> across restarts).
> PW
Re: How to check Radio in Menu Contribution [message #453558 is a reply to message #452780] Sat, 01 August 2009 11:57 Go to previous messageGo to next message
As mentioned I now tried it with RadioState like described in that blog entry:
I added the command:
<command
id="org.pubcurator.core.commands.setLayoutAlgorithm"
name="Set Layout Algorithm">
<commandParameter
id="org.eclipse.ui.commands.radioStateParameter"
name="State"
optional="false">
</commandParameter>
<state
class="org.eclipse.ui.handlers.RadioState:state1"
id="org.eclipse.ui.commands.radioState">
</state>
</command>
and added the menu item:
<menuContribution
locationURI="menu:org.pubcurator.core.menus.layoutResultGraph ">
<command
commandId="org.pubcurator.core.commands.setLayoutAlgorithm"
label="Layout Algorithm A"
style="radio">
<parameter
name="org.eclipse.ui.commands.radioStateParameter"
value="state1">
</parameter>
</command>
</menuContribution>
I would assume now that this would be enough to check that menu item by default (parameter value is
the same as state value), but it is not checked. Did I understand the RadioState thing wrong?
I also tried a HandlerUtil.updateRadioState(event.getCommand(), "state1"); in my programmatically
provided Handler, but still ... the menu item is not checked :-(
Kai
> setChecked(*)
> See:
> across restarts).
> PW
Re: How to check Radio in Menu Contribution [message #454727 is a reply to message #453558] Sat, 01 August 2009 14:49 Go to previous messageGo to next message
Here my workaround, but I don't think that this is the way it should be. For me RadioState doesn't
work on it's own.
private class SetLayoutAlgorithmHandler extends AbstractHandler implements IElementUpdater {
public Object execute(ExecutionEvent event) throws ExecutionException {
String state = event.getParameter(RadioState.PARAMETER_ID);
HandlerUtil.updateRadioState(event.getCommand(), state);
// Do what has to be done.
return null;
@SuppressWarnings("unchecked")
public void updateElement(UIElement element, Map parameters) {
String state = (String) parameters.get(RadioState.PARAMETER_ID);
ICommandService service = (ICommandService)
element.getServiceLocator().getService(ICommandService.class );
State commandState =
service.getCommand("org.pubcurator.core.commands.setLayoutAlgorithm ").getState(RadioState.STATE_ID);
if (commandState.getValue().equals(state)) {
element.setChecked(true);
> entry:
> <command
> <commandParameter
> name="State"
> optional="false">
> </commandParameter>
> <state
> </state>
> </command>
> <menuContribution
> <command
> style="radio">
> <parameter
> value="state1">
> </parameter>
> </command>
> </menuContribution>
> default (parameter value is the same as state value), but it is not
> "state1"); in my programmatically provided Handler, but still ... the
> Kai
>> to write a handler that can implement
>> setChecked(*)
>> See:
>> across restarts).
>> PW
Re: How to check Radio in Menu Contribution [message #479340 is a reply to message #454727] Mon, 10 August 2009 13:33 Go to previous message
Are you activating the handler yourself, or including it from a plugin.xml? From the plugin.xml it should go through org.eclipse.ui.internal.handlers.HandlerProxy.updateElement( UIElement, Map) which should handle the checked state for you.
If it is not, please open a bug https://bugs.eclipse.org/bugs/enter_bug.cgi?product=E4&c omponent=UI
PW
Previous Topic:PSF files : specify revision number of a project
Next Topic:Test Framework Update Site
Current Time: Sun May 19 17:21:00 EDT 2013
Powered by FUDForum. Page generated in 0.01780 seconds
